Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Major oil leak
    Re: Major oil leak
    Quote Originally Posted by ecogabriel View Post
    Most of the parts are inexpensive, but it takes time and work. Old car = leaks
    I would add to the potential leak sources the distributor shaft seal. It is inside the dizzy and seals the shaft... mine was hardened as a rock and the distributor internals were splashed with oil. Because of being EFI the oil mess got limited to the sensors in the lower half of the dizzy...
    That shaft seal is not a standard size (like the distributor bearing), but can be gotten online... can't recall if I got mine on ebay or from an online store.
    my 2 cents...
    thats the point of owning an old car, you get to work on it, you learn how to do your own repairs, mainly because of ridiculous labor rates, and the fact a lot of mechanics know nothing about these cars
    Mar 2010
    1989 Honda Accord LXi Coupe, 1995 Dodge Ram 1500
    Huntington Beach, CA
    Re: Major oil leak
    Am I correct in thinking that the timing belt cover gasket is not important?
    I plan to go order my parts tomorrow.
    Re: Major oil leak
    Quote Originally Posted by Harrison_Bergeron View Post
    it just keeps out dust a lot of people just run it without the top cover even in place
  1. Major Oil leak!!!!!
    By daprib in forum 3geez Accords
    Last Post: 08-17-2011, 10:01 PM
  2. Oil leak Found.. now an even worse oil leak....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 03-11-2011, 08:46 PM
  3. Heater hose leak, need to know if major damage
    By Coitis1 in forum 3geez Accords
    Last Post: 05-25-2007, 08:50 PM
  4. Major problem
    By lostforawhile in forum 3geez Accords
    Last Post: 10-02-2006, 08:05 PM
  5. Need Major Help!
    By Osiris in forum 3geez Accords
    Last Post: 08-02-2003, 02:02 AM
