My car is hemorrhaging oil, so I am making a list of all the possible culprits and will likely just replace them all.
Which of the seals in the diagram are the infamous oil pump seal leak? Is it #4, #9, and #11?
http://www.hondaautomotiveparts.com/...-+OIL+STRAINER
Are there any parts associated with the oil pump that should be checked if replacing the seals?
So, far I think my plan is to replace:
Front main seal
Oil pump seals
oil pan gasket
Oil filter base seal
cam seal
valve cover gasket and grommets
distributor o-ring
and, while it is apart the timing belt
Did I miss anything that causes a common leak, or that should be addressed while everything is apart?
This should be less than $100 for parts right?
I think that most of my idling/starting issues are caused by oil being where it doesn't belong. The car currently has way too much oil in it which I think is exaggerating the leak as well as causing oil to get in the cylinders.
