I got my Weber installed and have been driving it for about a week now.
Its working perfectly fine however when I shut the engine off, sometimes it will backfire and blow the rubber cap off the intake manifold that I had to seal.
Its not really a big deal, I used vacuum caps to seal it temporarily till I can get aluminum to plug them.
I just reach under the car and pick the cap up, put it back on and drive if it happens.
Also.
The big fat silver metal pipe that went into the exhaust manifold has no end to it, was temporarily plugged with a cork. Its the bigger of the 2 pipes going into the exhaust manifold. Itll blow the cork out sometimes resulting in a wierd sound as I accelerate. It hasnt had any negative affects but im worried exhaust fumes that havent been through the converter could be entering the cabin. I dont smell any gassy smells till I open the window.
Im wondering if the backfire or diesel or whatever it is doing could be because of that pipe being there. It has the tendency to blow the cap off less if the cork is out of the pipe.
Could there be to much exhaust fumes inside of the exhaust manifold that is causing this problems?
How did you guys plug that stupid hole up? Id rather plug it at the exhaust manifold itself to completely remove that pipe all-together.
It ONLY does this when I shut the engine OFF.
