Results 1 to 25 of 32
Thread: replacing rhf cv boots
    Jan 2010
    1989 Honda Accord SI 2L
    australia
    hello, Im trying to replace the rhf inner and outer cv boots on my honda accord 1989 si 2L but still can't access the shaft because the lower control arm wont come off, does anyone know how to take this off so i can access the shaft? here is a photo :
    Re: replacing rhf cv boots
    hammer the control arm to shock it loose (put the nut loosely back on just in case you miss the control arm). after a hard hit, or a few, you should be able to just lift it off
    LX User stephensimmons's Avatar
    Jan 2010
    89 Honda Accord LX-I
    summerville,south carolina
    Do what he said OR you could go to the parts store and get you a tie rod/ball joint seperator and get it loose.
    Jan 2010
    australia
    i just tried with the hammer and im real strong it didnt even budge ??? Isn't there a special tool for this that will definately work ?
    Jan 2010
    Quote Originally Posted by accord1989 View Post
    Yes its called a ball joint seperator
    oh i forgot to say to hit the side of the control arm.. did you do that? would probably be easier if you had the shock bolted to the control arm too. i suppose another way could be to put the wheel back on and drop the car violently lol. or just get a special tool like stephen said
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    it looks like you have the shock off, so put it back on.
    its needed for how i do it.
    put the nut back on the ball joint a few turns so you dont fuck it hitting it with a hammer.
    get a trolley jack and use it to lift up on the bottom of the bit that the wheel mounts to, the bit of the disc that pokes out from the disc is teh bit i mean.
    lift up on it enuf to put some load on the spring.
    then get a BFH and hit the arm where the ball joint spindle pokes through,just dont hit teh spindle.
    if you get it right,with the spring helping by pushing the arm down and the jack is pushing up, the shock of the hammer hit deforms the spindle hole just enough that it comes loose and the combined forces of the jack and spring push it apart enough that you just wind the nut off the end and shes done.
    the arm spindle hole dosnt deform permanently , just for the split second when you hit it with the hammer. i use a 36 oz hammer and it works pretty well
    AZ
    i bought one of these, http://cgi.ebay.com/HBM-HEAVY-DUTY-B...item562f1c5777
    best 30 dollars i ever spent.
    dead white and blue
    Jan 2010
    australia
    thanks put the shock on and hit it with a hammer downwards and it came off do i need to remove the spindle nut to get to the axle ? which way do i turn it ?
    Apr 2008
    88 LX sedan (sold)
    mi.
    yes you need to remove that nut. it will take a 32 mm socket i think. turn it counter-clockwise or to the left. the manual says to replace the spindle nut. i didn't,i just hit it with a screwdriver when i got it back on.
    Jan 2010
    australia
    well i tried the whole wheel turned even with the brakes down ?
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    It is a 32mm socket and it is normally threaded. Lefty loosey!
    By the by, my dad has an impact chisel + pickel fork = Ball joints come off in 10 seconds or less.
    '89 SE-i Coupe
    Awaiting Garage
    Jan 2010
    australia
    looks like i have to put the wheel back on then take off the nut lol
    Apr 2008
    88 LX sedan (sold)
    mi.
    stick a screwdriver in the rotor or something. it is hard to break loose.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Break that nut with the wheel attached, on the ground. No point in damaging your tools or brakes to save 30 seconds.
    Stat1k's tool is an excellent choice for the balljoints; However, a small amount of the tool will need to be ground off to access everything. A pickle fork will almost always result in damage to the balljoint or boot. A few strong hits with the hammer on the side of the spindle/LCA where the balljoint stud seats will ease removal and put less stress on whatever removal tool you choose. Never hammer on the balljoints or their studs.
    CARDONE SUCKS.
    Apr 2008
    88 LX sedan (sold)
    mi.
    Thumbs up Re: replacing rhf cv boots
    i stand corrected.
    Quote Originally Posted by LX-incredible View Post
    Second that. You're not saving any time by destroying your ball joint boots. I carry a pickle fork at the junkyard, but that's the only place.
    2drSE-i's Avatar
    Oklahoma City
    Third that, mine were destroyed. It was only an option because i had ALL new ball joints going in.
    '89 SE-i Coupe
    Awaiting Garage
    Jan 2010
    australia
    so hmmm is it really bad if the ball joint boot is broken or can i just say oh that'll be ok for today? lol
    as you can see in here , i dont think its torn just squashed up ?
    carotman's Avatar
    Montreal South Shore
    Here's the best trick to remove the lower balljoint
    http://www.youtube.com/watch?v=ISY8bGof3bQ
    Stick a ratchet or socket extension between the lower arm and the knuckle.
    No damage to the boot, no pain, no swearing.
    You can leave it without a boot but not for long. I wouldn't drive it except to get a new boot from the dealer. This is a critical suspension part in term of security.
    I need these parts!
    edit: nevermind
    That is genius!
    nfs480's Avatar
    Rogers, MN, USA
    I prefer using a Pitman Tie Rod puller to separate the lower ball joint, no risk of damage to the ball joint, available in the loan-a-tool at any autoparts store, and literally takes 30 seconds and is easy as pie.
    Jan 2010
    australia
    edit: nevermind
    edit: nevermind
    Jan 2010
    australia
    finally got it out removing the spindle with the wheel on was easy. now i am trying to replace the both cv boots here it is :
  1. Tie rod end boots
    By russiankid in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-21-2007, 06:10 PM
  2. Cv Boots
    By mattalica in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-09-2004, 12:41 PM
  3. Worth Replacing P/S Boots
    By DBMaster in forum 3geez Accords
    Last Post: 04-11-2003, 06:06 PM
  4. CV Boots
    By danronian in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-06-2003, 08:15 PM
  5. CV boots,
    By Mantis88LX in forum Classic Honda Community Chat
    Last Post: 08-31-2002, 11:18 PM
