Well i was amazed how the shift is smoother then hell then the old stock shifter. I bought a ebay short shifter for the fact i didn want to hack up an expensive piece. Pretty simple All that needs to be done is some grinding
Tools Needed.
Grinder of some sort. Dremel. Die grinder. Bench grinder. w/e
C-Clip plyers
Some Ice picks. I call em.
2 12mm wrenchs. One self racheting...Trust me.
10mm socket. 3/8 rachet.
ramdom plyers. and w/e you thing needed to suit you.
1. Pull down your Stock boot (mine is stock) from the clips on the Knob. Then turn your knob to Remove it. SIMPLE lol
2. Take off your center counsol that holds the boot in place off. Mine was a total of 4 Bolts. Dx style. LX-i comes a tape holder so your looking at 2 more screws.
3. Remove the Rubber boots from the shifters assembly. Now the to the fun part.
4. Take all the heat shield bolts off and removel the 2 exhuast hangers holding your exhuast up (under your cat). Take your time the shield is sharpe and will BUST YOU UP. if you have to bend it go ahead youll rebend it back to its shape when done.
5. Remove the bolt holding the bolt and nut in place. (2 12mm wrenchs)
6. Now go back up top and remove the big C clip holding the shifter in place then pull up. At this poing remove the Bushing on the Ball on the shifter. DO NOT BREAK IT. you well need this again.
NOW here you have the 2 side by side
you see how the ball on the Gsr short throw is alot bigger. THIS is where the fun begans. At this time pull out your Dremel or Air powered tool TO start grinding. You need to use a piece of string and wrap the stock ball and measure it. THEN cut the string to the right lenght
TO give you a good ideal how much to cut grind away on the other so you can check now and then. by wraping the string you measured and cut using the stock shifter.
after you done you should have this
Dont look nice but try to make it as round as possible. took me a hour with the dremel grinding this thing. so use what ever suits you grind away the shifter knob.
Once i got what i wanted i hit it with some fine sand paper so it wouldnt be rough. Then i coated the ball with a shit load of grease.
No test fit see it it goes in slight snug not to hard. move it around see if it drags.
You can see how it fits nice with no problems
At this time you can reinstall the C-Clip and now reattach the rubber boot. YOu wont be using anything esle. Once that is done GO back under and install the 2 brass bushing provided with the shifter you bought and Reinstall the bolt and nut you took off. (reinstall heat shield)
Once your all done you should have this
Now put your center consoul in and screw on your shifter knob and Pull up and boot to mate with the knob. LOL SIMPLE your done.
Now if you have your shield hitting your shifter i ran a big skinny bar down from the top (as in the car). and hit the shield the best i can. I got it enought so i wouldnt rub anymore.
BUT all and all it was worth it for a ten buck short throw and some grinding the shift is insanely short.
Thanks come again. ENJOY. NOW WHO SAID you couldnt put a Short throw in a 3g from another car LOL.
When done it will look like this with the everything put together.
In Netural
In 1st
In 2nd
RENDON.
