Results 1 to 9 of 9
Thread: cant open car door driver side
    Jan 2010
    1989 Honda Accord SI 2L
    australia
    installed a new window regulator in the driver door put the door panel back on but when i tried to push the inside door latch down to lock the door it wouldnt go down because is jammed onto something in the door lock so cant unlock or lock from inside or outside the door. so i thought i need a new door lock part for the door so i closed the door and when i tried to open it again it just wont open from inside or outside the door cause the lock isn't working, anyone know how to open any other way, I was thinking of kicking it open but i dont want to damage anything
    1ajs's Avatar
    slurpeepeg
    Re: cant open car door driver side
    pick up new door panel and do some surgery about the only thing i can think of
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    you've prob just bent or jammed something while you were replacing the regulator.
    pull the trim off and have a look see
    Dec 2009
    Killeen, TX
    try taking your door panel back off, when you look at the door latch that is inside the door (should be white with a piece that catches the part on the frame). The lock actuator is attached by 3 small brass colored screws. It is possible that the actuator is locked, but the latch was put back on when the door was set to unlock. I dont think this is very clear because i know what i am trying to type cause i just took my door apart saturday and had to replace the whole latch
    I think his door is shut and stuck, which means he can't get the panel off, If I do anything with a door lock, I always test the entire thing a bunch of times BEFORE I put the door panel back on.
    Jan 2010
    australia
    i,ve sorted it out, the latch was stuck on the striker so i had to pry from the inside the door to break the latch assembly now the door is bent all around the latch area but managed to get it open will post photos of it in the morning.
    Sounds like a pyrrhic victory to me.
    Mar 2007
    1988 Accord 4dr LXi & 1989 Civic hatch (w/ B swap)
    NoVa
    Done this on an altima before. We rolled down the window and shoved a long strong flat head screw driver down on to the latch and pounded away until it finally let go. Definitely a big PIA.
    Jan 2010
    australia
    ok so i installed a new latch ,i can open door from outside but not from the inside ? i can unlock from the inside if i lever the inside handle then pull up the door unlock but not by itself ?
  1. my passenger door won't open
    By 89cordlx in forum Classic Honda Community Chat
    Last Post: 01-03-2005, 06:36 PM
  2. door wont open
    By skull1441 in forum 3geez Accords
    Last Post: 03-18-2004, 11:40 AM
  3. my door wont open!!
    By 86ACRDLX in forum 3geez Accords
    Last Post: 02-06-2004, 02:02 AM
