Results 1 to 6 of 6
Thread: haltech interceptor
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    haltech interceptor
    so right now i'm running a stock accord ecu (P0A : 94-95 OBD-1 Accord EX) in the rwd haccord. fuel cut is something low 6200-6500? it sucks...
    i have the opportunity to get my hands on a Haltech Platinum Interceptor for next to nothing.
    now i know a piggyback cannot change the rev limiter, and i necessarily don't want it to much higher..
    so since i'm not made of money.. i plan on running an obd1 pr4 + Interceptor. i think the pr4 is 7200 or 7500 or something.. atleast now i can actually hit peak power instead of getting fuel cut just before. with this box i can set vtec/iab/fans.. and monitor/trigger a bunch of stuff and some once its all wired in.
    what do ya guys think.. i should have it setup for this weekends autox, and hopefully tuned as well.
    Re: haltech interceptor
    the hell kinda f22 u running mine stops pulling around 5200rpm even the factory dyno go around that renge
    and my rev limiter is around 7000rpm or higher if i recall
    88 Accord DX-RWD
    Kelowna BC
    weird... it was an 95 f22b2, your right tho it would stop making power roughly around 5k.. but would fuel cut around early 6000's
    i have 2 tachs in the car and confirm that the stock tack is correct, my vtec controller's tach isnt. i tried a diferent cluster (dc2) and it had the same reading as my stock cluster.
    the pr4 fuel cut should be 1k higher rpm than the P0B. i can correct fuel using the haltech, as well as monitor and control a hord of other devices with it.
    0bd1>* Get a chipped P28 or P06 and convert to P28 and chip.
    88 Accord DX-RWD
    Kelowna BC
    no magical internet purchase money card... and i'm sure this was cheaper as i kinda just traded some stuff for it.
    ^^ u can prob find a chipped ecu from someone local. Alot of honda guys chip them, and i know for a fact that swapped hondas usually have chipped ecu's, so hit up ur local scene for one.
    and if u wanna change the rev limiter, get the ignition box i have from summit... lol my limiter is set at 6900...
  1. Haltech/Motec turbo???
    By 87 Honda Prelude in forum Performance
    Last Post: 10-14-2002, 06:34 PM
