Results 1 to 10 of 10
Thread: Super slow acceleration
    Mar 2010
    Need some help figuring out what this could be:
    My buddy bought a 1988 Honda Accord DX Carb auto. It has some mileage on it (173XXX), Car seems cool and everything, but the seller told us that it might have a “clogged exhaust.”
    When he drives down the street, regardless on how much he is pressing down on the gas, it maintains a constant RPM, around 3K, until you back off so that the car can switch gears. This car has super slow acceleration.
    Thinking that maybe the seller was referring that the cat was clogged, I take it over to my exhaust guy to check it out. Take a look at it, says whatever it is, it’s not the exhaust. Think he might have been B.S.ing me, since it was close to closing time.
    So now I am left thinking, maybe it still is the cat, maybe I need to take a look at the timing but wondering if anyone else out there can make any suggestions.
    For what its worth, car idles fine, no backfire, nothing seems out the ordinary.
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    Re: Super slow acceleration
    Well to start cheap and do thingsprevious owner may not of done to help, would be things like..
    Seafoam in gas and into carb itself.
    Spark plugs of course
    Wires
    Timing
    You know, routine stuff.
    Then go from there to the more expensive options, especially checking the exhaust.
    Anyway, Seafoam especially can work wonders, especially for acceleration.
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    LMFAO never mind.
    for some reason I read the whole bloody thing, and remember it was a carbed...
    Rofl forget what I said. :P
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Honestly sounds like a TV cable Adjustment
    Check here
    https://www.3geez.com/forum/showthread.php?t=40885
    Adjust the TV cable, check transmission fluid level.
    If the cable is not the problem then check the carb Booster Venturies
    https://www.3geez.com/forum/showthread.php?t=48568
    If that doesn't work then maybe it's electrical or something is amiss in the trans.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Quote Originally Posted by Nio View Post
    LMFAO never mind.
    i hate to burst your bubble of fun but you gonna have to learn nio we know you dont have a carb car but it will help you down the road if you have a friend or a family member having trouble. and its good to learn new or "old" things
    hmm might wanna do a tune up and check the carb itself might not be getting enough flow due to carbon deposits and age if its a stock carb from 22 years ago. hmm i wonder if the vacuum could be the problem?... but for now do that and a fuel clean up and let us know if that helps. im not an expert on carbs im just learning my self. so any guys have more input or wanna correct me? go rite ahead
    Nio's Avatar
    Dec 2009
    1989 Accord SE-i
    Coronado, Ca
    Sorry. What I did was post a fix for his car....which I forgot was a carbed...I posted a fix for a FI system. *like how I got mine working*
    But after re-reading his post. I went. *OMFG I'm such a tard* that's why I put LMFAO....so I went back and edited my comment to that.
    I messed up and posted something that had nothing to do with his car.
    >.< made me feel like a complete idiot.
    Quote Originally Posted by A20A1 View Post
    Check here
    ditto, adjust all of it while youre in there, the accel cable too it if was mafunctioning it in turn would throw off the TV. Dont tie them together under the hood either. If the OP ever comes back....
    carotman's Avatar
    Montreal South Shore
    Make sure the secondary barrel is opening too
    I need these parts!
    Oct 2009
    lol let me guess you only read like 2 sentences right? it happens
    A20A1's Avatar
    Sep 2001
    Well said, I'm glad you two brought that up. Accelerator cable and Secondary, which are tied into each other. Strange that I aimed first for the trans but have dealt more often with accelerator cable adjustment nuts on the carb coming loose.
  1. Rev and Acceleration
    By rideordie12 in forum 2geez Accords
    Last Post: 01-01-2011, 11:54 PM
  2. Acceleration Problems
    By 87blueaccorddx in forum Carburetor Tech
    Last Post: 02-16-2004, 07:55 PM
  3. acceleration
    By jacc420 in forum 3geez Accords
    Last Post: 12-11-2003, 08:41 AM
  4. acceleration help
    By GDGuy11B in forum Performance
    Last Post: 11-10-2002, 01:26 AM
  5. Acceleration.....
    By 89AccordExi in forum Performance
    Last Post: 07-16-2002, 12:57 PM
