Page 2 of 9 FirstFirst 123456 ... LastLast
Results 26 to 50 of 214
Thread: The time has come
    Nov 2002
    Ridin Dirty in New York
    Re: The time has come
    Update:
    Waiting on brake parts, got to change my master cyl and pass side rear wheel cyl, had to order some decent flare wrenches and fluid as well...
    Nov 2002
    [IMG][/IMG]
    [IMG][/IMG][IMG][/IMG]
    Well the car runs and drives and I believe I fixed all the leaks and small ish... Its 85 in NY and the car ran cool around town, and I have the slim fan wired on all the time so thats good. I have the brake parts ordered so they should be here soon. Now the only issue Ive noticed, is that the car had great oil pressure, and it still does, at idle its about 25-30 psi hot, but it doesnt seem to want to get over 55psi, and wants to stay that way from 3000+ rpm... Im running 10w-30 and I still only have less than like 25 miles on the engine, do you guys think that could be trouble? I adjusted the clutch and the car feels much better to drive too
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    so your driving it?
    oh can you tell me the deka pt number for that batt?
    Nov 2002
    etx14. I didnt really drive it much at all and im still not until i get things ironed out... The oil pressure is making me think maybe the screen or the filter is getting plugged or somthing
    guaynabo89's Avatar
    FL
    why wheres it at?
    Nov 2002
    25-30psi at idle (1200 ish rpm) but it used to go to 65+ psi after 3000 warm and cold. Now it only seems to want to go to 50-55psi warm from 3000rpm+. Im concerned that somthing is wrong with either the pump or there is junk in the pickup etc...
    guaynabo89's Avatar
    FL
    chaned to a different brand of oil filter?
    I actually noticed a couple of psi diff when switchhing from a kn oil filter to a regular purolator
  8. #33
    Nov 2002
    whats your normal oil pressure when warm? I have a wix filter... I havent changed the oil yet though
  9. #34
    guaynabo89's Avatar
    FL
    I'll have to double check, but I believe it's in the 55-65 area. I'll get back to you on that one.
    I'm using 20-50 as well
  10. #35
    Nov 2002
    Also I was thinking, I need to find the correct spark plug wires for my car. I have the cyngus obd1 conversion kit, so the NGK wires i have dont even come close to fitting, what are good wires that fit?
  11. #36
    Oct 2000
    '88 Accord LX-i
    Connecticut
    looking good and I am sure you will get those little bugs worked out soon
    '88 LX-i Coupe --- LS/Vtec
  12. #37
    sounds like a oil pump issue. if anything you can shim the housing. Those togas are known for epic fail. yet some say its good. My oem at idle was 25-30 and at 3k it was at 40 and at full wot 98 plus. no matter where im at if i smash it it jumps to 95
    Nov 2002
    im thinking of swapping to a new oem honda oil pump but majestic honda doesnt seem to carry anything for our cars anymore, so im checking other places.
  14. #39
    is there a napa around your area. They carrey good pumps.
    guaynabo89's Avatar
    FL
    sorry im a little late.
    after engine is warmed up using 20/50 castrol and kn filter im at 50-53 at idle (8-900) and up to 70 at 4k+rpm.
    Sound the same as yours?
  16. #41
    Oct 2000
    '88 Accord LX-i
    Connecticut
    it is time, gather the others...
  17. #42
    guaynabo89's Avatar
    FL
    wtf!
    that's my line.
  18. #43
    Nov 2002
    with the 10w-30 im only at like 50-55psi warm over 3k. I have a new honda pump on the way, so im going to try changing it, the oil, and the oil filter.
  19. #44
    SEi User
    Jan 2004
    sloppy gearchange, i made up a ally bush to go into the linkage on teh gearbox, this makes it nice and tight feels like proper race car change!!
  20. #45
    guaynabo89's Avatar
    FL
    I'm also planning on going custom_
    , only I'm going to use Derlin plastic.
  21. #46
    yay! i dont think ive ever seen pics of your car before O.o how long has she been down?
  22. #47
    Nov 2002
    like almost 3 years dood. I blew up the stock motor with my first turbo setup, then put in a built motor, had problems with that, sold my turbo setup almost entirely, started over and built an almost all new setup and here we are today.
  23. #48
    Quote Originally Posted by rjudgey View Post
    yeah i need to try that...on mine it was missing a heat sheild and my poly busshings melted under the exhuast heat...i dont think our transmission is strong enough...i already broke 2 with NA set ups
    89T's Avatar
    Apr 2004
    jason how's the car running?
    un-motivated!
    3GR
  25. #50
    Nov 2002
    ive got alot of stuff going on right now so I havent been able to work on it much at all lately... sorry guys
  1. alrighty its that time again...... rant time
    By buttaz1 in forum Classic Honda Community Chat
    Last Post: 05-08-2007, 09:22 AM
  2. tax return time = upgrade time!!
    By hootymo in forum Classic Honda Community Chat
    Last Post: 02-08-2005, 09:20 PM
  3. Long time viewer, first time poster.
    By bc86 in forum Classic Honda Pics & Videos
    Last Post: 07-24-2004, 10:47 PM
  4. time to kill my 3gee ? or time to ....
    By bboipinoy112 in forum Classic Honda Community Chat
    Last Post: 07-31-2003, 12:22 AM
