Results 1 to 16 of 16
Thread: Anybody actually use their Mosselman turbo manifold??
    Nov 2014
    1987 Prelude 2.0Si
    Seattle
    A few years back some 3geez members did a group buy on the Mosselman turbo manifolds. However, I haven't been able to find anyone actually using the manifold...what gives? Did everyone just give up??
    I'm about to go B series swap on my 1987 Prelude using info mostly from 3geez, but the idea of FI on the A20 wouldn't be totally off the table for me. I would consider it, but I find it odd that I can't find a Mosselman build on an A20.
    With the Mosselman do you need to remove AC or PS? What is the flange type?
    Re: Anybody actually use their Mosselman turbo manifold??
    i dont think anyone has a running accord with one of those manifolds yet. I sold mine shortly after the GB happened to a local member, and eveyone else is doing the long slow proper builds instead of slapping a turbo on and blowing stuff up then asking why it happened lol. Idk about the AC & PS but i know its a t3 flange.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    You should have plenty of clearance for the power steering and AC compressor your best bet is to have an intercooler with both outlets on one side switch that half size Honda Civic radiator T3 T4 spacer plate in between the manifold header and turbo. Cutaway partial motor mount holder
ID:	7595   Click image for larger version.
    LX User knifemind's Avatar
    Mar 2008
    88 dx & 85 Lude
    Montana
    Wow, that's some cutting into the block/mount. I shaved mine on my spare block a bit, but I actually ended up deciding to mount the turbo "upside down."
    Edit: Is that how much you had to cut to get it to fit even with that extra flange in between? (Is that a BMC flange?)
    Feb 2016
    Florida
    Yes the turbo so big barely has any clearance. And yes that's from BMC Machining. That piece is coming out eventually. Maybe I should have went with the littler Turbo I'm pretty confident the two remaining studs are strong
    Feb 2016
    Florida
    Live and learn
    Feb 2016
    Florida
    Knifemine show pictures of your build or it didn't happen lol thanks
    Mar 2008
    88 dx & 85 Lude
    Montana
    Nice.I have a BMC flange also...never used it for anything, though.
    My build is not running yet. Here it is on my spare block. I'm about 95% there and am just waiting on a local guy to build me a flange adapter for my intake. Then I just need one more order of silicone depending on what size the intake ends up. Probably going to be a 3" pipe. Originally I was going to run into a B16 intake, but since I decided to rotate the turbo, I thought I would run it into the stock A20 manifold. (A20A1, carb manifold)
    I have not figured out the exhaust yet, but I'll think of something. I'm either going to just run it straight down the engine bay, or possibly do a less than ideal 90 degree bend.
    In case you just went "WTF?" ...yes, This is going to be draw through turbo with a Holley 500. The carb is going to end up behind the left headlight.
    Feb 2016
    Florida
    Looking good can't wait to see it inside the car
    Feb 2016
    Florida
    What are you using as engine management are you going obd1?
    Mar 2008
    88 dx & 85 Lude
    Montana
    There is no engine management. It's carbureted, so all the "engine management" is mechanical. The only electronics involved is the ignition because I have a Megajolt crank fired ignition. Fuel is metered through the modified carb with boost reference to allow more fuel under load. And of course I run a wideband to monitor AFR
    Feb 2016
    Florida
    That's right you have to be fuel injected to go obd1. Crazy Build dude keep up the good work. I thought about turning the turbo upside down too but then it would throw my down pipe layout completely off with nowhere to run it. You may have to upgrade to that front lower frame replacement suspension bar . For clearance
    dont use the carbed manifold. be smart run an IC, and use a b16 intake. you will make gobs more power and it will be fully tuneable.
    Mar 2008
    88 dx & 85 Lude
    Montana
    No IC. This is drawthrough carb. Fuel is going through the turbo so an IC is impractical/dangerous. I am smart, and I am building it this way with intentionality. I was going to push into a b16 manifold (minus the throttle body..or maybe a gutted throttle body) because the turbo to intake distance was very short, but since i decided to flip the turbo the A20A1 manifold is the best solution with minimal fab. I have been studying drawthrough setups for years (literally) and am mostly doing this as a proof of concept that a drawthrough can be both viable and reliable. If I can get the compressor to clear the block & mount without hitting the radiator, I will go back to the B16 manifold, but I'm still waiting on a couple more things to arrive (plus a work trip soon) before I start in-car fitting. Assuming I am successful, eventually I plan to make (or have made) a turbo manifold designed with my specific carb application in mind. I'm also really looking forward to using my modified oil pan.
    This suck through idea will work even unintercooled but I think you might be better off going blowthrough just for simplicity sake. You will probably lose about 100 degrees F going blowthrough unintercooled from one side of the carb to the other plus your throttle response will be better. You would have to mod the carb for blowthrough but the fastest turbo carb guys I've seen have all been blowthrough. You could even intercool it too. I'm trying to put together a single turbo blowthrough for my friends Ford 5.0 powered mercury comet
    Quote Originally Posted by knifemind View Post
    Curious if this ever got finished.
  1. Mosselman Turbo Manifold FOR SALE!
    By Vanilla Sky in forum For Sale
    Last Post: 09-11-2016, 03:01 PM
  2. For Sale: Mosselman Turbo Manifold!
    Last Post: 11-29-2014, 05:38 PM
  3. Mosselman turbo manifold 260 shipped.
    By ghettogeddy in forum For Sale
    Last Post: 04-24-2014, 06:59 PM
  4. Mosselman Turbo Manifold For Sale!
    Last Post: 02-18-2014, 11:46 PM
  5. Mosselman Turbo Manifold Group Buy
    Last Post: 11-10-2013, 09:23 PM
