AccordEpicenter
Ill have to see if i can find some order info for my diamond pistons, they are stock profile for the most part, except they are bigger bore and smaller skirted i believe and the wrist pin size, but the compression and pin heights dont change, plus Ron at diamond is an awesome guy.
No B18C rods dont fit. Youll need B18A/B rods... B18A/B rods are the same in every aspect to stock A20 rods except for wrist pin diameter
im not really sure what the differences are with the flywheels, i have an aasco unit and i was told they are uber hard to come by these days.
200hp with a btm and safc is doable but your better off going obd1 because after you buy and install/fuck around with the btm and safc you could have had the much greater flexibility of the obd1, ESP if your planning on going for higher boost (over 10-11 psi) i would highly highly reccomend the obd1. Dont forget to upgrade injectors and fuel pump as well
