Results 1 to 7 of 7
Thread: carb head with sei cam shaft
    Aug 2008
    1987 honda accord lxi hatch
    lincoln
    has anyone ever combined the two because i searched and found out that lxi cam shaft with carb head makes more power how about an sei cam shaft
    Re: carb head with sei cam shaft
    The SE-i is just an LX-i with cosmetic changes, except for the exhaust.
    not worth the swap...get a delta 272 to get a better top end out of your engine.
    Aug 2008
    lincoln
    ok just thought i would ask but only reason asked is cause my head is knocking and the only head i can get at the moment is a carbed one well thanks guys
    the carb cam lift specs are a little different but not too much. I don't think you would even notice and power loss.
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    The heads are interchangable. If the cam in your current head is good you can reuse it in the carbed head.
    Aug 2008
    lincoln
    yea i searched to see if they were interchangable and found out they give me a little more power so i said why not.
    i almost have the head off at the junk just got to remove one more bolt from the carb and it should be good to come off
  1. EFI head on carb engine ?
    By Whistler225 in forum Performance
    Last Post: 11-12-2006, 09:24 AM
  2. carb vs efi head
    By bgaccord in forum Performance
    Last Post: 03-28-2004, 10:01 AM
  3. cv shaft or axle shaft question
    By buzzbomber88lx in forum 3geez Accords
    Last Post: 12-24-2002, 08:36 AM
  4. EFI head vs. CARB head
    By pric in forum 3geez Accords
    Last Post: 11-25-2002, 05:57 AM
