I am having charging issue last couple of weeks. I have searched through many thread and gave me good idea how to approach the problem but I still can't pin point partially because I have no idea about car electrics.
The problem started when my wife tried to start my Aerodeck (A20A4, Injection, identical to A30A3 except A20A4 has no cat), battery was dead. I quickly charged up the Red Top Optima with battery charger and after 5 mins, it managed to clank the motor and was ok.
Next day when I drove, it started ok but now showing charging warning light on dash board. It was not constant, intermittent but somehow I managed to drove 20min to my son's school, stop the motor, managed to start again and came home.
I removed and charged up the Optima with main fed battery charger and it says fully charged. I drop it back to car and started ok. I test drove around town include slow traffic and 60m/h fast traffic about 30 min with using no electric accessories like heater or light and came back. Check with electric tester on the battery terminal, the reading was 14.5V while the motor is running. As a test, keep the motor running and turned head lights, rear defogger, heater blower full and the voltage reading is going down like hell, like counting down. When it went under 12V in may be 10 second, I turned accessories off, then the reading went back to 14.5V again.
I was assuming by this time that alternator is charging but when the load is high, it can't supply enough. So as a last test, I turn heater blower at lowest, wiper on, small light on then I drove around for 30min, no problem, reading was 14.5V when motor is running, when stop, the tester reading of the battery is about 12.5V. There was not charging warning light.
What do you guys think, whats wrong with the alternator? Rectifier? Diode?(even I don't know where they are).
The trouble alternator is refurbished unit by Lucas UK about 10 years ago and I bought it as old stock brand new refurbished on ebay recently and installed it about a month ago(call it no.4) Originally it was for carb, I opened it and I have changed the rectifier (the board with 3 or 4 pin connector) from my old Denso alternator(call it no.1). This old alternator(no.1) was working fine when I removed it 4 years ago. I swapped no.1 with refurbished one (call it no.2)'just in case' if the original one (no.1) was at its limit before our long trip (when I look back now I should have left it, I know!) The no.2 has died after one month on out trip to Netherland (ouch!) and I have no choice than buying questionable refurbished one (call it no.3) in Amsterdam. This €480
no.3 has been working but the bearing was making grinding noise badly so I decided to change to no.4.
The optima battery is 4 years old and it had flat only one time because my son has left room lamp on over nightApart from this red top has been working wonderful.
Any suggestion is welcome.
