Results 1 to 25 of 28
Thread: rpm to high
    rpm to high
    so i went to smog the hatch today and the rpm is to high
    about 1250 or so
    how can i get it below 1k just for a smog check
    the only thing i noticed was #1 is loose or broken
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Re: rpm to high
    Is that your idle screw? If that's loose then tighten it up and it'll drop your idle.
    Re: rpm to high
    it almost feels broken
    like you turn it and it just turns
    nothing else
    and its wobbly
    Re: rpm to high
    there is a scerw in there, tightent it to lower the idle thats what i did when my 3g had a high idle
    Joay's Avatar
    Sep 2008
    Re: rpm to high
    That's the FITV. Just a band-aid but if all you need to do is keep it down for the test it could work.
    Re: rpm to high
    ya the high ideal dosent bother me any
    just as long as its low when i take it in
    Re: rpm to high
    anyone else got any suggestions
    Re: rpm to high
    usually if your idles high due to either a vacuum leak or idle screw/fast idle valve adjustment it will do that gay rev bouncing thing. which leads me to think the throttle stop screw may be holding the TB open or ur cables too tight etc
    either that or it is a vacuum leak and ur TPS is fucked
    Re: rpm to high
    it does that but not all the time just very occasional
    Re: rpm to high
    theres a oring that seals the idle screw.
    I have a few laying around here if you need them.
    Re: rpm to high
    i thikn that screw is snapped i have to take the red line off to see if it falls out
    of so im gona need a extraction tool
    oh and the filter box you gave me apparently the 87 -89 had dif bolt holes lol they dont line up
    but the dude at the smog place did not care
    Re: rpm to high
    I also have a spare throttle body if needed..
    Re: rpm to high
    yay
    hope fully it plugs into the 87 lxi intake mani
    maybe a shop day at my house
    Re: rpm to high
    can this be done with the car on or does it need to be off and how much tightening are we talking about 1/4 turn
    1/2 or more
    Re: rpm to high
    I have one of those in the parts shed also if u need it geddy
    Re: rpm to high
    well hopefully i dont brake it lol
    Re: rpm to high
    Dang. Pico got the hookup! Watchu need? Pico got it.
    Re: rpm to high
    woot...time to get the car on the road
    Re: rpm to high
    yup ypu
    reg is coming back around lol
    this time i dont need smog lol
    May 2008
    los angeles
    Re: rpm to high
    1/2 or more
    you should keep it off man.. i did it once with the little plate open and my idle sky rocketed haha... just adjust it.. close it and run it.. if not then do it again til your happy.. its one of those trail and error gigs ya know?
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    DX User AlfredoPDX's Avatar
    Sep 2006
    89/honda/Accord Lxi
    Re: rpm to high
    I was having the same problem today, lucky i found this thread. Thanks guys
    May 2008
    los angeles
    Re: rpm to high
    Quote Originally Posted by AlfredoPDX View Post
    no prob
    -Tom
    Re: rpm to high
    ya to bad it did not work for me lol
    im gona need a new throttle body lol
    May 2008
    los angeles
    Re: rpm to high
    you still havnt changed it?! haha
    -Tom
    Re: rpm to high
    Quote Originally Posted by 1987AccordLx-i View Post
    not in a hurry trying to get the elantra back to almost full working lol
    the back 2 windows dont work the regulators are shot pos cable kind
    i just replaced the front drivers side corner light need to smog it soon
    insurance so forth so on
    it just hasent been a priority to be putting miles on the hatch
  1. 3g idling in high RPM ?????
    By rfiks in forum Carburetor Tech
    Last Post: 07-19-2009, 09:00 PM
  2. What's too high on the RPM??
    By alanizgod in forum Performance
    Last Post: 12-29-2008, 05:33 PM
  3. High Rev A20?
    By Bass Man in forum Performance
    Last Post: 06-05-2008, 01:22 PM
  4. Very High KM
    By Koopsta in forum General Engine Swaps
    Last Post: 02-12-2005, 02:09 PM
  5. Failed Emissions: High HC ppm's & High CO%
    By 98serwtricks in forum 3geez Accords
    Last Post: 06-15-2004, 09:24 AM
