Results 1 to 19 of 19
Thread: Raybestos/AC Delco rear adjustable upper control arms
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Question Raybestos/AC Delco rear adjustable upper control arms
    So I was browsing Rock Auto the other day and saw these parts listed on their site. Raybestos and AC Delco both seem to make adjustable rear upper control arms for our cars. I am curious as to wether anyone has tried these yet? and had any experience with the quality of them? IMO, the Raybestos one looks a bit more robust, but not sure.
    I am thinking of trying some out to help with my camber issues, and using the Moog control arm mounts to get rid of some negative camber in the front end.
    I am replacing my ball joints and tie rods, etc right now while doing my motor work, and I have OEM rear upper control arms i bought a while back, but I want to try something with the adjustability.
    Here are some pics:
    Raybestos Part# 5021018
    AC Delco Part # 45D1018
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Raybestos/AC Delco rear adjustable upper control arms
    Both are chinese and not the best in quality. The Raybestos pictured is actually made by SPC, which is quite decent aside from the balljoint. You can probably find a better price for a SPC set on egay and replace the balljoints with quality honda/moog/three-five (555) units.
    CARDONE SUCKS.
    https://www.3geez.com/forum/showthread.php?t=48440
    I got the old pictures some where I'll post them up if you want. they sent me one of one style arm and one of the other so I sent them back. I think I am about 50/50 on Rockauto so far.
    I am happy with the Ingalls arms.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    i would go with the raybestos one , overall the design looks a lot better than the AC delco. One thing i do like better about the Raybestos part is the ball joint carrier the raybestos one looks casted while the ACdelco one looks welded on. Im going to be buying a set of these soon to start my se-i rear disk swap
    3Geez resident body man
    Owner of Wreck-less auto body
    LX User GLICIOUS21's Avatar
    Apr 2010
    89 HONDA ACCORD LXi
    RUSKIN,FL
    I need a better expensive set of lower cntrol arms. If u know of a red finished set that r adjustable please send me a link.
    BIG N BAD WIT VTEC
    Mar 2008
    I agree the raybestos looks better, but they're 100 apiece and i don't see them anywhere on ebay.
    Sep 2006
    Tucson, AZ
    http://motors.shop.ebay.com/__?_from...rd+spc&_sacat=
    CARDONE SUCKS.
    Mar 2008
    gotta pay to play i suppose lol
    Sep 2006
    Tucson, AZ
    When I bought them it was for the set.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible View Post
    so if i buy these i can buy a OEM ball joint and use it with the SPC arms?
    very interesting, if the ball joint was replaced with a better one, you would have a decent arm. the main advantage, is you could replace the ball joint instead of the entire arm.
    Dec 2003
    Millington, TN
    Yep.
    Phil
    Washington
    Not sure if anyone else has tried this lately but the cost is a bit higher at Napa. 117 a piece part number 260-5115. Comes out to the SCP one pictured above. The arm itself looks plenty strong but the ball joint as LX-Iincredible says its stamped made in china right on it. The old napa part that is just the arm is the AC Delco part and is currently discontinued. That being said they still have stock of it. Myself, spending 117 on the part is a bit out of my range to drop another 50 on a different ball joint. Im going to wait till the cheap chinese one fails. My current arms or so worn out you can move the joint inside the housing. Great info in the thread so far, just trying to keep it alive.
    - ingalls 38600 adjustable arms with poly ends.
    - moog k9736 bushings
    have you priced these out? I just added a grease fitting to mine and they hold up.
    I believe there non-Chinese parts since I don't buy China but I could be wrong.
    Im disgusted with Rock auto at the moment, well not really them but Raybestos..I ordered two of these Raybestos Part# 5021018 and they came to me as standard non adjustable arms. They are pretty and all but F me this is not what is pictured or described in the catalog under that number.
    They are offering to refund my money if I send them back, but that doesn't help me finish the car while I have milder weather to work in....
    I should have known $29 each was a tease, I just ordered two from NAPA, for $35 each. I had the parts guy acknowledge what is in the NAPA prolink catalog, these are adjustable rear UCA w/joint.
    Rock needs to correct the catalog asap.
    Yeah in this case I would stick with the Ingalls, or I guess there SPC now, arms. I think Rockauto means well but they can't keep track of all the parts they sell and what they really are.
    So far with the grease fittings mine have stayed tight. Prolly would be better if I greased them once a year but I never remember too.
    f bomb
    Ok I just got the NApA arms, NCP 2605115 and they are the same dam way. The catalog clearly describes them as adjustable w/ball joint, shows a picture of it and dam if they aren't in the same box, wrapped the same way as the Raybestos arms, and duplicates of OEM and NOT Adjustable.
    Now I have money tied up in credit card returns and pretty much dead in the water on this for now.
    Calgary, AB, Canada
    f bomb
    That's brutal... I almost ordered the Raybestos ones off of Rockauto at $30 a piece this week too. Good luck getting this sorted and let me know what you find.
    Ok, I reordered these from Rock auto, but without the ball joint. They came as the correct part. Funny thing is though the boxes were unopened, identical, but the parts were wrapped different and they look like they are made of different materials
    They look different as well from the picture in the first post. Still seem pretty stout so I am keeping them. Raybestos Part#6111090 $48.79 each
  1. Replies: 0
    Last Post: 01-24-2013, 11:08 AM
  2. Nice adjustable rear upper control arm -2 to +4 deg.
    By POS carb in forum Performance
    Last Post: 08-16-2012, 02:36 PM
  3. SPC rear upper control arms
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-23-2008, 08:44 PM
  4. New Rear Upper Control Arms On
    By mushroom_toy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-22-2008, 08:55 AM
  5. rear upper control arms for sale
    By njpeter in forum Trading Post
    Last Post: 06-27-2003, 07:25 AM
