mushroom_toy
Yeah definitely find that circuit if you can I might try that. Yeah the gsxr tbs are around 42mm I think, so it should work reasonably well, also they were already set up amd spaced with spacers so the almost matched up perfectly to the a series manifold, when I had my runners welded on, I just had the runners conform to the tbs instead of lengthening the tb spacing, so theyre pretty much almost stock spacing, so there is only 1 adjustment to adjust all 4 together, or you can adjust each one seperately, but i dont plan on doing that since each individual tb should have been set right from the factory and im pretty sure they havent been messed with.
ill try to take and post some pics up soon of my tb setup, I read a lot of your pages on pp originally, but Id still like you to give any suggestions you might have when you see mine.
