question is an 86 lx trans the same as the 89 lxi because the trans in my coupe is going bad and i have an 86 lx that i could use
Well yes, there is. But I can only think of 2 reasons to use an aftermarket fuel rail. 1) you need one custom drilled for non-Honda style injectors. 2) You like it because it looks cool and you have money to burn.
An aftermarket throttle body isn't going to get you anything either unless you have a seriously built engine already. The stock B18 TBs are big enough to handle a fair amount of power.
The best place to put your money into on these engines is the head. And then of course intake/header/exhaust.
C|
the lx tranny to me feels like it makes my lxi lowered geared.I have ran to different lx ones in mine an both of them was the same.I think they are that way cause lx was lower hp.I know on interstate you can really tell diff.
'88 LX-i Coupe --- LS/Vtec
so i just got the trans out what a bitch it took me 4 1/2-5 hours now i need to clean it but how do i do that without ruining it?
I love the carbed tranny...70, 80 or more mph on the expressway and im at around 3-3200 or so....love it
~~NGK~~Silvania~~MSD~~Pioneer~~MSW~~Bosch~~DC Sports~~115WHP 116WTQ
yeah i did i watch them lol to make sure they click the right things
okan ls is a b16 right? because this crack head dosent know whathes talking about
"its a bare ls manifold. It wont work on a b16"
ok so second gear works intermittently when under load like if the car downshifts getting on the highway it will go straight to redline until i let off the gas and i shifts back into third or forth. or if i lock it in second by the shifter its just like being in neutral sometimes it works though. ive been told to change the fluid but i dont think that will help.
you need to adjust the throtle cable that goes to the tranny
nvm the wonderful guys at the naugatuck autozone helped me figure it out it was the pcv valve. the only problem was that i couldent get the bottom of the old valve out i had to break it inot peices cuz it was so brittle and i know a few pieces fell down into the tube hope it dosent hurt too much neext oil change im gonna drop the pan clean it and change the gasket. how hard it it to change the fromt main seal mine is leaking kinda bad
ok cool thanks
