Can exhaust leak from the exhaust 'joints' or gaskets? Do you periodically swap them out to keep that from happening? Or they should not be a problem?
Also if the muffler comes off the hangars, is there supposed to be all kinds of play down to the cat? or is the cat supposed to be braced still? (I haven't looked at that closely lately & no lift.)
Can exhaust leak out of the engine compartment and draft into the cabin?
How about entry from rear bumper into trunk?
Can changing O2 sensor/s clean up exhaust any if no check engine light on?
Going up big hills the exhaust in the car can get pretty bad.
Thanks.
