OK ITS 11:23PM GUYS. US PACIFIC TIME ZONE PEOPLE R GOIN 2 CATCH SOME Zs. I WILL WAKE UP GO 2 WORK COME USE THE HOUR OF LIGHT LEFT N CATCH YALL AGAIN ROUND THIS TIME. PEACE![]()
BIG N BAD WIT VTEC
h22 in 3g
and h22 in a 2g!!
VERY WIN
if it fits in a 2g it fits in a 3g :p
Where'd you find that 2gee hatch??
what do you mean?
All CB7 used cable transmission as well, so if you have a transmission that uses shift rods, then its not for an h22 motor. If it was a transmission designed to work with the H22, its got to have cables and a shift box. The only way to use a transmission with a rod is the b-series transmission mod.
^ troof.
dead white and blue
Ha ha. Surprise this thread aint locked from the whole world still talkin ish. Um done wit that and i just want to talk bout my car and this swap.
BIG N BAD WIT VTEC
Actually your misunderstanding me. Yes that transmission has a hyldrolic clutch. I am not speaking about the clutch tho. I am speaking of the shift mechanism, the piece hat goes from your hand to the transmission. A, b, and d series engines tend to use two metal rods, and a shift lever. C, h, f, and k engines tend to use cable transmissions that uses cables and a shift box to change the gears. Your car is designed to use a shift lever, not a shift cable setup.
what he is saying is the h22 has a cable shift transmission, you need the entire shifter assembly out of a car with an H22, has nothing to do with the pedals, or anything else. the 3g has a solid shift rod that acts directly on the transmission, and a torque rod, the torque rod is connected to the shifter and to the transmission, the other end is in a bushing up under the car. as the transmission moves with the engine,it rotates slightly, the torque rod slides back and forth in that bushing at the rear, and the entire shifter attached to it, moves with it, this allows the shift rod to always move freely and never bind up, since the entire shifter and shift rod,move together with the transmission. On the H22 it doesn't have that, it has cables attached to the shifter assembly, and a shift box, why they went to all that complexity, I don't know, but you need the entire shifter to make this conversion work. you have to install it, and all it's cables into your three g. Now the clutch cable, you have a hydraulic clutch on the tranny for the H22, and you have a cable on the three g, you are going to have to remove the pedal assembly from the three G, and change your clutch pedal to a clevis,like the brake pedal, the rod from the clevis will have to go through a bushing on the firewall, and you'll have to install a clutch master cylinder to operate off of that rod. you should be able to use just about any Japanese clutch master, most of them have the same threads, some even have a clevis built into the end of the master cyl rod, if you can find one like this, you may be able to bolt the master cyl right to the firewall and hook the clevis up to the pedal arm. don't forget to put in a doubler plate where the master cly bolts in.
This may work for the clutch convertion, there are also Hydro to Cable conversions that bolt directly onto the transmission.
thats pretty slick, I wonder if there's enough room under our dash for it to work? If I was doing the conversion I would use spherical rod ends at both ends and build a bracket for a junkyard master, probably a nissan, but for someone who doesn't do much fabrication, this is a great setup
