Results 1 to 25 of 35
Thread: 1987 accord lxi wont start
    Jun 2010
    1987 honda accord lxi
    Clearwater fl
    Unhappy 1987 accord lxi wont start
    one night at the store it wouldnt start. after 3 weeks of sittin when i was about to junk it. i tried it n it started rite up but ran and misfired really bad. started up a few times after that. but wouldnt start again. i was about to get the fuel pump replaced but the man who was gonna do it tried to steal my part. so i pushed it to my aunts house n i decided to mess wit the ignition i touched something n i tried to start it again n it started after 1 failed attempt. i replaced the spark plugs wires distrib cap n rotor and it ran great 4 a week n then it wouldnt start again what is my problem
    1ajs's Avatar
    slurpeepeg
    Re: 1987 accord lxi wont start
    check you ground wires one of them might be just sitting there or your ignition switch is worn and needs replacing
    Jun 2010
    Clearwater fl
    i dont kno what wires that would b im kinda learning as i go
    1ajs's Avatar
    slurpeepeg
    theres a wire bolted to the top of ur motor that mounts to the front of the engin bay above the rad check that
    also how dirty are your fuel filters?
    Jun 2010
    Clearwater fl
    K i kno what wire that is. But i dont kno where my fuel filters are i looked under the driver side but i dont c any thing unless unless what im cn is an access panel or sumthin n my fuel pump only whirl sumtimes but i do smell gas after have tried to start it a few times but it sounds like it not gettin any gas. N should i replace dis wire or what? Thanks
    1ajs's Avatar
    slurpeepeg
    Quote Originally Posted by hersheys87 View Post
    i am going based on fractured bits but what ur aying now definatly sounds like a failing fuel pump
    theres a filter where the line comes into the engine bay and one in the "rear wheel well area" witch you should change
    Jun 2010
    Clearwater fl
    k im gonna replace da fuel pump n get a new filter n it only seems to start trippen at 1/2 a tank
    I am guessing you have a carb. Try keeping your gas cap loose and see if that might help it. Also make sure your choke is open when your car is hot and not slipping shut when you goto start it hot.
    Jun 2010
    Clearwater fl
    No its fuel injected. Does it still have a choke
    No choke on a fuel injected car. Ive said this a thousand times, but Ill say it again. You should make sure it's not the main fuel pump relay first. Try turning the ignition to the spot right before you start cranking the engine (ACC), Listen for a click from under the dash (behind the fuse box), and then you should hear the fuel pump prime(kinda of a humming noise). If you don't hear that, it could be the relay. If you could get your hand on top of the relay, you can actually feel the relay click if its working.
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    Fuel system check list:
    1.Check for clogged fuel filter
    2.Check fuel pump fuse
    3.Check fuel pump main relay
    Check those first
    And if I were you I would inspect the fuel pump,filters and strainer and see the condition of the parts if they look old they need to be replaced with new ones. Especially the fuel filter and strainer<located inside the gas tank.
    I changed every part in my fuel system to make sure I keep track when I changed so I know what would need to be changed if I have a problem. That's just me though
    Jun 2010
    Clearwater fl
    Exclamation Re: 1987 accord lxi wont start
    i can feel da relay click. But i dont hear da humming. I even tried to hook up the new pump n i still didnt hear anything or c the pump cum on n i kno it works cause i tested it on the battery n it came on .n a few times i didnt feel the relay click on
    Jun 2010
    Clearwater fl
    Angry Re: 1987 accord lxi wont start
    i resoldered da main relay and changed da fuel pump. I can feel da relay clickin again but i still dont hear da fuel pump cum on. Rpmh goes up to about 800 n i replaced da coolant temp sensor. Since my ecu was blinkin 6 times and it still wont start .i was gonna replace da fuel filter but i think i have da wrong one i believe da 1 i need is slim and da one i have is kinda fat n short please help me its drivin me crazy
    www.rockauto.com for pictures and stuff there real good.
    its under the hood passenger side on the firewall.
    Carefully you can put some fuel into the intake and see if the car will just fire. You need spark and fuel at the correct time for a car to start. Not a whole lot to it. Hang in there.
    I still think the relay is bad. You can use a 12volt test light to see if you have voltage at a wire at the fuel pump it self. there very handy,and cheap, for cars.
    Jun 2010
    Clearwater fl
    Red face Re: 1987 accord lxi wont start
    i replaced the relay n the car still wont start. The pump isnt gettin any power. Is that the only fuel filter i have the one n the pic but i thought it was suppose to b one located near the tank . And does it matter if i dont bolt the relay n it is very hard to get back n
    LX User Jajle's Avatar
    May 2010
    1989 Honda Accord SE-i Coupe
    Yukon, Oklahoma
    i replaced the relay n the car still wont start. The pump isnt gettin any power. Is that the only fuel pump i have the one n the pic but i thought it was suppose to b one located near the tank
    That's not a fuel pump, that'd be a fuel filter. Your fuel pump should look like this.
    And it should be located in the trunk right above the gas tank. Unless it's different for LX-i than SE-i.
    I love my 3Gee so much!
    Jun 2010
    Clearwater fl
    [QUOTE=Jajle;1026927]That's not a fuel pump, that'd be a fuel filter. Your fuel pump should look like this.
    And it should be located in the trunk right above the gas tank. Unless it's different for LX-i than SE-i.[/QU yea my fuel pump looks like dat
    Jun 2010
    Clearwater fl
    Lightbulb Re: 1987 accord lxi wont start
    Da auto part store gave me the main relay for a dx and not a lxi so hopefully when i go get the correct one she will start up. I hope so cause not havin a car is a big drag.
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Autozone carries the factory Mitsuba Main Relay RZ-0028 that came in these vehicles. It is Part#19235 at Autozone. The only reason I would ever say Autozone is because it is the factory original and not a knock off. It will come in a Duralast box. And should look like this.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    Jun 2010
    Clearwater fl
    [QUOTE=Bluntman;1027279]Autozone carries the factory Mitsuba Main Relay RZ-0028 that came in these vehicles. It is Part#19235 at Autozone. The only reason I would ever say Autozone is because it is the factory original and not a knock off. It will come in a Duralast box. And should look like this.
    [/QU autozone hade a fuse i even used da part number u gave me it was n a durlast box but wasnt the main relay the stated that they dont carry that part at all i guess i gotta go to honda
    Actually u could solder the one u have. It's very easy, just take the black cover from the top, then re-solder all the leads on the bottom of the exposed circuit board. Very simple, and only takes an hour depending our your soldering skills.
    Apr 2009
    Orange County Cal.
    [QUOTE=hersheys87;1028607]
    Quote Originally Posted by Bluntman View Post
    They lie!!!!!!!!!!! I just pulled up 88LXi, but it is the same for yours. I have bought more than one there. Hell print this out and take it with you. There website is screwed up at Autozone under 87 LXi it only showed a fuel cut off relay which is wrong for FI. So just go back and ask for 88 LXi main Relay. Print and take this with you from there site.
    http://www.autozone.com/autozone/par.../N-ii131Z9cjg2
    And here is the NAPA part # for 87 LXi http://www.dmauto.com/web/dmauto/Cat...mfg/ECH/AR333/
    SE-i Sedan 5 spd
    Just curious....do you talk like you write?
    Jun 2010
    Clearwater fl
    [QUOTE=w261w261;1028728]Just curious....do you talk like you write?[/QU. Yep. but i can switch it up if needed. I dont need proper grammer to post.
    Jun 2010
    Clearwater fl
    Question Re: 1987 accord lxi wont start
    i ran a wire from the battery to the pump n i can hear fuel goin to the engine but it still wont star t what could it b
  1. 87 accord wont start
    By Civic Accord Honda in forum Carburetor Tech
    Last Post: 12-29-2007, 11:47 PM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. 87 accord lx wont start help
    By g0ldfinGa in forum Classic Honda Community Chat
    Last Post: 03-02-2004, 11:38 PM
  4. accord wont start now.
    By Festo in forum 3geez Accords
    Last Post: 11-18-2003, 08:12 PM
  5. My Accord wont start
    By Fusion1976 in forum Classic Honda Community Chat
    Last Post: 10-04-2003, 09:29 PM
