Originally Posted by
stat1K
b and d-series blocks do not have the same mounting points, nor do they use the same mounts. the only chassis that this could be considered with is the EK chassis, however, the b-series mounts for that chassis are specific to the chassis itself, not the motor.
for example:
to put a d16y8 from an EK chassis car into say an EF you use the EF mounts, not the EK mounts, therefore the B-mounts for the accord are exactly that, to fit a B-series motor into the chassis. since the mounts on the D from the EK chassis are different than those of the B16A2 that came in the 99-00 Si it would not work that way.
