Results 1 to 4 of 4
Thread: i need the wiring guru!!!1
    Oct 2002
    89 honda lxi
    sharon PA
    ok here it is. I shaved the whole back of my car, and i got these leds with a ground/tail/brake light wires can i hook up a turn i ran it like i aways do in other car but our 3gs got some little boxes and a weird system in the tail lights. if this makes any sensce to u can you help!!!1
    Oct 2002
    89 honda lxi
    sharon PA
    ok i played with these wires and i got it all working. But.....the tuns only work when he light parking or headligts are on.
    SEi User jigga225's Avatar
    Louisiana
    run a seperate lead for your turn signals, they need to be on when the IG2 switch is on.
    Find where the original turn signal wire comes from and you can use that one
    10/Honda/Ridgeline
    NJ
    never mess with a honda unless u know what ur doing. it will bite u in the ass, well unless if u have one :weird: i am sooooooo screwed.
    k back on ur topic, what did u do with the boxes? it should not give u any problem as long as u have the wiring harness intact and just either splice it to make ur custom job. also u know that the lil boxes are brake bulb blow off sensors.
  1. Question for a guru!
    By lostscotiaguy in forum 1geez Accords
    Last Post: 04-13-2010, 06:33 PM
  2. Questio for the suspension Guru
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-02-2005, 07:13 PM
  3. need help carb guru's
    By 87accordlxxx in forum Carburetor Tech
    Last Post: 04-11-2004, 07:15 PM
  4. To all the guru's.. Help me design an enclosure!
    By pimp86LX in forum Interior & Exterior Care
    Last Post: 07-16-2003, 05:22 PM
  5. Mr. Guru, God, All-knowing suspension guy...
    By pearldrop in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-25-2002, 08:04 AM
