Results 1 to 7 of 7
Thread: temperature gauge not working
    Sep 2006
    1986 Accord, 1987 200SX SE
    Guerneville, Ca (Bay area)
    So I feel like I am posting a lot of threads and I hate to clutter up the forum, but I did searched and couldn't find what I was asking.
    So Pretty much my Temp Gauge is not working, though my gas gauge is working so that checks out, also tried grounding out the yel/grn wire and nothing changed. Wire did not get hot (Not sure if it should lol) and gauge needle stayed way below the C zone. I was going through some wiring diagrams and I saw there was a 10amp fuse for it, but where is it? lol. Pulled all the fuses on the driver side and in the engine bay.
    Fans do come on, once I get my volt meter back I will check for hot at the yellow/green wire. the dash has the Reverse Indiglo gauges, not sure if that helps out. I am thinking maybe that part of the gauge got messed up on install?
    Any help would be great, thanks
    Feb 2009
    87 Honda Accord DX
    Baltimore Md
    Re: temperature gauge not working
    ithink that shares a fuse with your defroster's, try replacingthe temp sending unit 20 bux off of rock auto , fixed my probloem
    Sep 2006
    Quote Originally Posted by bryan42688 View Post
    But eeven if the sending unit is bad (Which I thought it would show hot all the time) I tried grounding the wire and nothing changed. Soooooooo idk
    89T's Avatar
    Apr 2004
    the guages temp sensor is a 1 wire sensor on t-stat neck.
    un-motivated!
    3GR
    Sep 2006
    With the male end on it right? If so I am pretty sure that is good
    89T's Avatar
    Apr 2004
    yea! male on the sensor, and female at the wire. that wire goes to the square plug right behind the headlight. It's right next to the battery so i would check for corosion for sure. After that it enters the fender area and runs into the cabin just in front of the door.
    You checked the sensor resistance?
    un-motivated!
    3GR
    Sep 2006
    Hmmmm I didn't know about the square plug, I'll check that for corosion for sure, because the plug was pretty nasty and I had to stripe part of it to get a good spot for grounding, And no I haven't yet, I need to get a muti-meter so I can check it.
    Thanks for you help
  1. How Does Your Temperature Gauge Behave?
    By kw_da in forum 3geez Accords
    Last Post: 10-15-2006, 09:50 AM
  2. temperature gauge location? (PLEASE LOOK AT THIS PIC))
    By detroit313 in forum 3geez Accords
    Last Post: 03-21-2006, 09:24 AM
  3. Temperature gauge reading low?
    By Poodlehead in forum 3geez Accords
    Last Post: 08-25-2003, 08:35 PM
  4. does anyone w/ new guages still have WORKING FT gauge?
    By bobafett in forum 3geez Accords
    Last Post: 12-12-2002, 11:28 PM
  5. Temperature Gauge
    By Seabass in forum 3geez Accords
    Last Post: 11-05-2002, 11:39 PM
VigLink badge
