Results 1 to 10 of 10
Thread: clicking noise front left wheel when turning
    Jan 2010
    1989 Honda Accord SI 2L
    australia
    everytime i turn right i get a clicking noise in the left hand front wheel, plus a thudding noise when on a rough road ??? also the front brakes are starting to sqweak ??? honda accord 1989 2.0l si
    King Peetis's Avatar
    Atlanta, ga
    Re: clicking noise front left wheel when turning
    Time for new half shafts. Your CV axle boot(s) are bad for whatever reason and the grease inside is either gone or contaminated. Nothing will fix the problem only replacement will do at this point. Look at your axles both inboard and outboard and inspect the boots for damage. Troubleshoot first then shotgun.
    Dec 2003
    Millington, TN
    Time for a CV shaft.
    Phil
    Feb 2009
    87 Honda Accord DX
    Baltimore Md
    is it a manual shift or an automatic i would defentally say start with the cv axel's both ofthem and if your car has a manual transmssion , unless you just replaced the clutch or know the history of it iwould start with replacing that , not that the clutch has anthing to do with the clicking its justgood practice and the axels can some time be a b*tch
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Quote Originally Posted by bryan42688 View Post
    Im sorry, but what sense does it make to replace the clutch for no reason in particular?
    Anyway, like the others have said, sounds like its time for an axle.
    Jan 2010
    australia
    its auto and there is no grease in the left cv boot , there are no tears or leaks in it ? so wandering what the previous owner did there? or does grease just dry up?
    If the boot is intact, how do you know there's no grease?
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    No, grease usually does not dry up, as in evaporate or disappear. Grease can however separate in to a liquid and paste. Some agitation will put separated grease back to its proper consistency.
    I'll guess the previous owner replaced the boot and forgot to install the grease that is usually supplied with the boot kit. If the boot has no cracks, tears or other openings there is no exit path for the grease to escape from the joint. If there was no grease installed in the joint; there is no reason for any to be there now.
    Atlanta, ga
    Quote Originally Posted by car6289 View Post
    This is a strong possibility. Inspect the axle boots again and determine if the boots have an obvious seam for closure and hose type clamps (split boot repair kit) securing it . If so, then the boot was definitely a replacement and the previous owner most likely omitted the grease. The boots are installed on the axles when you buy them and there is no seam and the bands securing the boot are not adjustable. FYI, the longer you drive your car with this condition the more dangerous the situation becomes.
    Feb 2009
    87 Honda Accord DX
    Baltimore Md
    just replace the axels and gofrom there , and the clutch is for insurance purposes
  1. Ball Joints??? Front end popping/grinding noise when turning.
    By BrokenBone in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-08-2011, 04:44 PM
  2. clicking noise when turning left
    By geeteedan in forum 3geez Accords
    Last Post: 09-20-2009, 03:59 PM
  3. werid Squeaking noise from left front
    By alboy86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-28-2007, 06:32 PM
  4. Clicking noise in the front
    By Fuzy Navel in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-09-2006, 11:12 PM
  5. strange noise when turning wheel!?!
    By Chrome_thangs in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-27-2002, 08:44 PM
