Results 1 to 5 of 5
Thread: Sloppy handling
    Jul 2010
    UK
    Sloppy handling
    So having been enjoying the Aerodeck for a few weeks I've had to face up to some minor probs. I find the ride is quite sloppy (for want of a better word) and doesn't feel overly composed around the bends. I have checked the shocks and no leaking so I'm trying to work out what it might be - is there anything that is prone to wear? I'm thinking bushes but hope not as these are always a pain to change.
    AZ
    Re: Sloppy handling
    every bushing in the car i'm sure is destroyed and in need of replacing.
    the rubber in the bushings is at least 21 years old at this point. You should replace the LCA bushings front and rear, the sway bar bushings front and rear, the rear trailing arm bushings, the strut bushings, and it's a good idea when doing this to replace the upper and lower ball joints as well. i would also check the steering rack for any type of play as the tie rod ends could be worn and also in need of replacing. this is something that is also recommended when doing bushings as the parts are already off the car making it kind of a why not type thing.
    bushings aren't really a pain given the proper equipment, now if you are in an environment with moisture then yes, it can be a pain since rust is the enemy. and seeing is how you have an aerodeck you are most likely in europe making the rust woes all the more serious.
    i did the entire front end all at once on my civic and i have to say it's not a bad job but i have a 20ton press. the front lower control arms were the worst to get out.
    dead white and blue
    Jul 2010
    UK
    Re: Sloppy handling
    Thanks mate - I'm in the UK so it is a bit wet here. Do you get the bushes from Honda or is there somewhere better to source them from? Assuming not cheap for the whole lot?
    There also seems to be some movement or the engine under load - engine mounts?
    AZ
    Re: Sloppy handling
    yeah if you're getting a lot of vibration it's pretty common for a mount to be bad. most common is the front mount on these cars.
    as for the bushing i'm not sure what all works, i know that if you search lx-incredible 's responses in the suspension threads you'll find a lot of the information you need.
    dead white and blue
    Aug 2009
    89 Accord Aerodeck EX
    England, UK
    Re: Sloppy handling
    Hi AB, i've got an Aerodeck too, and I'm in the UK. Any photo's of yours?
  1. idle is sloppy
    By girlcrazy_4 in forum EFI Tech
    Last Post: 07-04-2006, 04:35 AM
  2. 88 LXi sedan handling
    By mouchyn in forum 3geez Accords
    Last Post: 04-16-2005, 01:11 AM
  3. handling plans
    By lightbulblxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-23-2004, 07:31 PM
  4. whats the best size for handling?
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-27-2003, 09:12 PM
  5. freeway speed handling
    By K DASH in forum 3geez Accords
    Last Post: 09-25-2002, 10:59 AM
