Results 1 to 5 of 5
Thread: Temp guage quit working
    Jun 2010
    My temp gauge quit working, I am guessing my check engine light should come on soon and tell me what it is. It happened 5 months ago, was engine temp sensor, replaced it and now not sure if it went out again or something else. Just trying to get any help in what it could be in case check light does not come on. Its a 88 honda accord lxi, 2.0 fuel injected. Just installed water pump day before.
    Re: Temp guage quit working
    there are two sensors, one for the ECM and one for the guage...
    One wire sensor is guage, two (sometimes three) wire sensor is for ECM
    Any thing else not working on the intrument cluster? I would check fuses if so
    Temp guage can stop reading if the thermostat gets stuck open
    Temp guage sensor should be on the intake manifold somewhere
    Sensor for ECm is around the thermostat housing somewhere
    The gauge wire plugs onto a little nipple that sticks out the back of the thermostat housing. Make sure it's not unplugged or so loose and sloppy that it doesn't make contact.
    this, also crimp a new contion on the wire i had the problem of mine acting werid for 2 years then i crimped a new contection on it worked fine ever since
    Jun 2010
    mine bounces around sometimes, just smack the gauge cluster and it goes back to where it should be =p
  1. Temp guage stopped working
    By MoDawG in forum 3geez Accords
    Last Post: 11-24-2007, 02:32 PM
  2. a/c quit working
    By 86-accord-lxi in forum 3geez Accords
    Last Post: 08-14-2007, 02:41 AM
  3. One headlight door quit working
    By Kelvin in forum 3geez Accords
    Last Post: 06-01-2007, 11:49 AM
  4. Temp Guage NOT Working
    By hitz2hard in forum 3geez Accords
    Last Post: 02-25-2006, 05:09 AM
  5. Temp Guage Not Working
    By tightwhitelx in forum Carburetor Tech
    Last Post: 01-11-2003, 12:27 AM
