Page 33 of 61 FirstFirst ... 2329303132333435363743 ... LastLast
Results 801 to 825 of 1520
Thread: Have a quick question? Ask it here!
  1. #801
    re: Have a quick question? Ask it here!
    the only direct swap would be another 88-89 engine. can can try to swap it over to mt when doing a swap.
    Sep 2012
  3. #803
    LX User EbidaDragon's Avatar
    May 2012
    1988 Accord LX Sedan
    Gwinnett, GA
    Am I to worry if I turn on my car's HEAT button and the nice, beautifully warm air only comes from my side vents and under-windshield vents? I need to check again, but I feel like with just the dial(slide switch, whatever >_>) up to max heat, and normal VENT on bypassed that odd issue.
    It's probably me still not knowing exactly about climate control, but I thought I should ask
  4. #804
    Sep 2012
  5. #805
    May 2012
    Gwinnett, GA
    Quote Originally Posted by Stealth View Post
    The manual says the center vent(s) has a switch in the center to keep your face cool while the HEAT setting is selected. By "side vents" do you mean the thin ones up on the door or the square ones on the dash?
    I just mean the rectangular/square ones on the side of the glove box/steering wheel, on the dash. I need to look through my manual again >.< Picked one up from a lucky find at the PaP
  6. #806
    Sep 2012
  7. #807
    five vent selections:
    vent (four dash vents only)
    high/low (four dash vents, four lower vents for feet)
    heat (four lower vents for feet, two front two rear)
    heat/defrost (heat listed above, plus the vents along the windshield and the two on the door sills)
    defrost (vents along windshield and two on doors sills
    "fresh" opens the vent to let air flow in from outside of the vehicle
    "rec" recirculates the air inside of the vehicle
    air conditioning...enough said
    All 1986-1989 LX's, LX-i's and SE-i's have the ability to close the center vents individually. The switch is up/blue for open and down/white for closed. Like mentioned above, it bypasses the heater to blah blah. (Not available on any DX.)
    All 1988-1989 models have the ability to individually close the outer vents on the dash, closest to the door panel (NOT the ones on the sills). This is done by the levers on the lower-right side of the steering wheel. (Not available on any 1986-1987 models.)
    To completely shut off the climate control, select high/low, recirculate, disengage air conditioning, manually close the dash vents and turn the fan off. Driving with the fan off but the "fresh" button selected will still force air into the cabin while you drive.
  8. #808
    It's unusual for the vent controls to go haywire on these cars. I would start by looking at the door motors in the dash. If one isn't working properly, it can keep air from blowing where it should.
  9. #809
    May 2012
    89 lxi hatch
    Ok so my (89 lxi) auto Trans went out on me 2 day so i was looking on line an was wondering can i us a auto trans from a civic or a later model accord seeing how i a rebuild is way out of my budge
  10. #810
    May 2012
    89 lxi hatch
    Ok so my (89 lxi hatch) auto Trans went out on me 2 day so i was looking on line an was wondering can i us a auto trans from a civic or a later model accord seeing how a rebuild is way out of my budge
  11. #811
    nope it would have to come from another a-series engine
  12. #812
    2.0Si User ShyBoyCA6's Avatar
    Oct 2009
    89 Honda Accord Coupe
    OK. um where does the resonator go on our cars? i been doing some searching but nothing comes up exactly where it goes. i know what it does but just not where it goes. does it go after the cat? or behind the muffler? any help is great! thank you.
  13. #813
    Quote Originally Posted by ShyBoyCA6 View Post
    After the cat
  14. #814
    Oct 2009
    Thank you Pico.
  15. #815
    Jan 2013
    1988/honda/accord
    Does anyone know where I can get some cheap coilovers for my 88 accord dx hatch
  16. #816
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    ^ You can use any generic 88-00 civic coilover sleeves, you can get those at your local speed/performance shop or ebay but If you want full body coilovers, then ksports/D2 are the cheapest.
    1989 Honda Accord LX-I 300K+
    Build Thread
  17. #817
    May 2012
    central Ohio
    Umm ..., what are coilovers?
  18. #818
    LX User Shawn87AccordDx's Avatar
    Oct 2012
    1987 Accord Dx
    Kent, WA
    Questions you think are too stupid to ask...Ask them here!
    How do you know if you need to replace your springs when you do struts/shocks?
    shawnseeley.com <-- my blog
  19. #819
    Jan 2013
    1988/honda/accord
    check out rgrah011 on utube for 88 accord
  20. #820
    Nov 2008
    Las Vegas, NV
    Technically its any coil spring over a shock (like what we have in our cars), hence the name "coilover" but most people associate them with aftermarket coilover which are stiffer than stock springs and can adjust the height of the vehicle. Aftermarket coilover have two different designs, a sleeve design and a full body design.
    Quote Originally Posted by Shawn87AccordDx View Post
    If they seem to have any damages (broken, heated, cut) I would replace it or if the car leans, if not your springs are still good.
    Build Thread
  21. #821
    DX User JDAccord88's Avatar
    Jan 2013
    1988 Honda Accord lx
    Georgia
    Ok so my 88 accord lx (Carburetor) has had some problems like my headlights never turn off except when the car is off and it will star then just die shortly after starting. I hae changed the Dist. Cap, Rotor ignition button, spark plugs, valve cover gasket (leaking oil) and i have changed the Vacuum Advance Dist. It only has 174,xxx miles but runs as if it has twice that much. Any feed back would be awesome.
  22. #822
    May 2012
    central Ohio
    Two dumb questions to add to this thread: What is meant AE86 theme? What does CA5 mean?
  23. #823
    Quote Originally Posted by JDAccord88 View Post
    Try removing the air filter assy and inspect the carb. Spray the top inside of it wit some good throttle body cleaner and make sure all vacuum lines are connected, no broken lines, no collapsed lines.
  24. #824
    CA 5 is a manufactors model number for some of thes Hondas. Like C3 is a certain year/style Corvette, K5 is certain style Blazer etc..
    AE86 style ( 80's RWD toyota corolla) I don't get that reference as used here recentley , well I think I do in that it means semi flat black panels and graphics on an otherwise regular base color. I could be wrong but I actually went looking for pics of them to get cool two tone paint schemes.
  25. #825
    May 2012
    Gwinnett, GA
    AE86 is a body style of fifth-generation Toyota Corolla, last RWD 'Rolla, I believe. Not sure if it's part of the VIN, like:
    CA5 is a body style of third-generation Accord, but I don't remember what exactly differentiates the CA body codes
  1. Quick question need help quick
    By mushroom_toy in forum 3geez Accords
    Last Post: 09-13-2009, 10:59 PM
  2. quick question...
    By Kemikals in forum 3geez Accords
    Last Post: 08-24-2007, 01:52 PM
  3. quick question
    By spanky in forum Classic Honda Community Chat
    Last Post: 12-21-2005, 05:04 PM
  4. Quick Question
    By Glowin Smurff in forum Classic Honda Community Chat
    Last Post: 02-22-2004, 06:16 PM
  5. Just a quick question....
    By Mike D in forum Classic Honda Community Chat
    Last Post: 11-26-2002, 04:55 PM
