Page 5 of 61 FirstFirst 1234567891555 ... LastLast
Results 101 to 125 of 1520
Thread: Have a quick question? Ask it here!
  1. #101
    re: Have a quick question? Ask it here!
    From what I've read, A/C is kinda hard to install with the big black box behind the dash - I think.
    As for the power steering: all models have it. Check your belt. If it's bad, replace it. If it's good, spray it with Belt-Ease.
  2. #102
    AC will be a lot of work to install. Most people think it's a box that you screw into the dash. It's more like 200 different parts that get installed all over the car. Then another 200 parts get modified to adjust idle to compensate for compressor load, or turn on the cooling fan when the compressor turns on, etc.
    And, welcome to the board!
  3. #103
    Quote Originally Posted by jknox8 View Post
    Sup everyone, new to the site and the reason I just purchased a 1989 Accord DX 123K love it, runs like a champ! My only question how difficult/expensive is it to add a/c to one where it was not installed from factory? Not a big deal, just curious, also, does my car have power steering? If so, its out as well, how difficult is that to replace. I did a search for the a/c question, no luck, but didn't about the power steering, i get a squeal think its out but don't even know if it was availbale on it. Looking forward to chatting and getting to know everyone better! thanks in advance for the replies...
    when you can take pictures take a pictures or many pictures of the duct that connects the blower on the far right side of the car,to the heater core in the middle of the dash, almost no one here has factory AC delete, and wants to see what the duct looks like, since it won't have an evaporator box
  4. #104
    Dec 2010
    Thank you all, yes I will get pics hopefully tonight for everyone! No problems. Now I am certain its either a bad/loose power steering belt, difficult to turn sometimes and the screaching it all adds up! Thank you everyone for the input and quick responses...look forward to talking with you all in the future.
    I figured as much for the a/c was hoping it might have just been a bolt on slightly modified under 400 bucks issue but sounds like mass work and $$$ so nm. Just sweat I guess! lol
  5. #105
    While you're working on the PS, change the oil in the system.
  6. #106
    Dec 2010
    never done that before, pretty self explanatory? how difficult on a 1-10 scale? changed oil, done brakes, tune-ups, alternator replacement, stuff like that. Is it pretty easy to get to, etc.
  7. #107
    Pretty easy. The manual describes how to do it on p. 18-9. The hardest part is figuring out a way of keeping the old fluid from shooting across the street when you start the car.
  8. #108
    LX User HON-DUH's Avatar
    Oct 2010
    Question here, whenever I have the radio on, along with the front and rear defroster, headlights, my revs go down.
    How many amps does the stock one have?
    Will 135 amps suffice?
    http://cgi.ebay.com/ebaymotors/86-89...#ht_1064wt_941
    Is it time for a new alternator?
    If so, is the installation simple?
    Thanks
  9. #109
    Oct 2010
    double post
  10. #110
    When I use anything in my car the idle goes down. Even when I steer and brake. All of my Accords did that...
  11. #111
    That's a damn good price for a high output alternator. Last time I tried to get one new, it was over $200-300. It would be much more straightforward than converting to the Legend alternator.
    Honestly though, your stock alternator is more than capable of running everything in your car as it is (assuming you don't have some mega-stereo). You might go through all the grounds and battery cables and clean them up, maybe replace some cables. That makes a HUGE difference, and is cheap. But yeah, you will always get a slight drop from the extra load on the alternator.
  12. #112
    Oct 2010
    Yeah, me too, whenever I'm at a red light and I press the brake pedal, my revs go down and the car starts to vibrate a little, it gets annoying...
    I have the stock radio with stock speakers, so yeah.
    So if I make sure all my cables are ok and if I replace some, my revs should stay constant no matter what I do, correct?
  13. #113
    Quote Originally Posted by HON-DUH View Post
    that doesn't sound like an electrical issue, it sounds like your brake booster or it's check valve has a problem, the brake lights don't draw so much current that they would load the alternator, stepping on the brake causes a large change in engine vacuum, if the check valve is ok, there is enough vacuum stored in the booster to not have much effect, but if it's not it would suddenly show the engine a large vacuum drop
  14. #114
    Same with all of mine. I've gotten used to it. My battery and alternator are about six months old.
  15. #115
    Dec 2010
    89 Honda Accord lx
    Oklahoma
    Well this is my first car and i want to lower it, i know im going to need coilovers( not going with lowering springs) and shocks and camber kits (to get negative camber) thats all i really need right? Just the main to lower the whole car is coilovers and shocks right?
  16. #116
    Quote Originally Posted by Salo_89_Accord View Post
    https://www.3geez.com/forum/showthread.php?t=89
  17. #117
    Dec 2010
    89 Honda Accord lx
    Oklahoma
    Can't believe i didn't see that
    Thanks!
  18. #118
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    What type of gauge pillar pod "fits" for my accord..
    I want the battery/oil and maybe one more gauge, I need a gauge pod pillar thing.
  19. #119
    Okay, at this point I'm seriously asking for someone to hold my hand and walk me through this:
    How do you take off the rear bumper? (coupe)
    I've read the how-to thread, but it wasn't specific enough and there weren't pictures.
    I know about the four screws near the tires, and that once the four 12mm bolts are off the bumper slides back, but I can't find the bolts!
  20. #120
    the ones that hold on the tow hooks, and i think one more on the sedan, they will all be inline with each other, the pieces that hold on the bumper slide into the frame rails
  21. #121
    Quote Originally Posted by CzEcHy View Post
    This one works great.
  22. #122
    LX User resendez's Avatar
    Nov 2009
    88 accord lx-i
    peoria, AZ
    i saw camber kits on ebay that claim they will fit an 88 accord and they are $20 or some thing is it true they will work i want to slam and camber wheels like this /\ but i dont know the first thing about camber or how to go about doing this. any help would be verry appreciated i only want the rear cambered.
  23. #123
    Quote Originally Posted by resendez View Post
    why would you want your tires cambered like that? do you own a tire store?
  24. #124
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    stance.
  25. #125
    stance.
    ooooooooooooooooooo, the "my control arms are broke" look, I want one of those cool exhausts like that now!!!
  1. Quick question need help quick
    By mushroom_toy in forum 3geez Accords
    Last Post: 09-13-2009, 10:59 PM
  2. quick question...
    By Kemikals in forum 3geez Accords
    Last Post: 08-24-2007, 01:52 PM
  3. quick question
    By spanky in forum Classic Honda Community Chat
    Last Post: 12-21-2005, 05:04 PM
  4. Quick Question
    By Glowin Smurff in forum Classic Honda Community Chat
    Last Post: 02-22-2004, 06:16 PM
  5. Just a quick question....
    By Mike D in forum Classic Honda Community Chat
    Last Post: 11-26-2002, 04:55 PM
