Page 54 of 61 FirstFirst ... 444505152535455565758 ... LastLast
Results 1,326 to 1,350 of 1516
  1. #1326
    DX User 1989_3rdGenAccord's Avatar
    Jun 2015
    1989 Honda Accord LX-I 1988 Honda Accord LX-I
    I replaced the distributor, cap, rotor, plugs, wires and coil along with an oil/filter change. Everything was NGK except the distributor.
    I move the distributor, angle the light in every way, rev the engine ect.. and still no mark. I even put a fresh mark on there just to be sure It can be seen.
    The tdc mark on the flywheel does not line up with the crank mark. If the dot on the crank is lined up with the half circle on the engine block then the tdc mark is not lined up and vice versa.
  2. #1327
    Jun 2015
    I followed the manual to set the timing to a T and still no mark.
  3. #1328
    here is the two marks you are looking at on your flywheel. This is a picture from below the car.
    You are using the small "window" cut out in the bell housing to check? Its below where the distributor is located and is usually covered with rubber plug. These cars dont use any marks on the timing belt to line up the crankshaft.
  4. #1329
    Jun 2015
    Yes, that's the mark and the location.
  5. #1330
    just by your pictures I think you are using the front of the engine to check the crank position is why I posted that.
    Don't really have any advice really other than take it to someone that can do it for you.
  6. #1331
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    All right one of the first questions I asked was it original or aftermarket distributor and I never really got an answer back. Now that I see that it's a replacement distributor. I have had no luck with replacement Distributors I always recommend OEM. If you still have your original distributor that works put that back on and try that
  7. #1332
    Jun 2010
    In your 1st post you said you reset the timing because they told you it could be a tooth off... did you pull the timing belt off either end?
    Originally posted by ShiRen:
  8. #1333
    Jun 2015
    Sorry I didn't catch that one. I put in a rebuilt OEM. Mine was bad and not rebuildable.
  9. #1334
    Jun 2015
    When I Reset the timing the first time I did so by lining up the crank dot with the half circle and moved the cam over one tooth so that the cam marks would then line up with the head. To do that I loosened the belt.
  10. #1335
    Jun 2010
    It's very easy for the crank to shift when tightening the tensioner back down, may want to check that it didn't move on ya.
    Ignore the crank dot, you set it by the "T" on the flywheel/flexplate for initial install when lining up cam/crank. Cam at "UP" position in line with engine and crank at the "T". Just have to make sure the crank doesn't move when tightening down the tensioner as it does like to do it.
  11. #1336
    Jun 2015
    That is where I'm at now. I still cant see the mark on the flywheel and I still have a misfire. Does anyone have any idea what I should do next?
  12. #1337
    Jun 2010
    Take off timing belt and reset timing completely using method described above.
  13. #1338
    Jun 2015
    Yes I have done that. Today I used a can of sea foam in the intake. Seems to run better but now the idle is staying at 1000 rpms (normal 750-800)
  14. #1339
    Quote Originally Posted by 1989_3rdGenAccord View Post
    If you have an auto, then you have the 2 marks pictured above. You also have a dot or two. Do NOT use the dots to line up the crank. Use the T or the cross. Don't use the number. Use the T. If you're confused, upload pictures of how you're lining it up and we can advise.
  15. #1340
    Jun 2015
    Yes I used the + not the numbers and not the dot and i still cant see the mark when checking the timing. I also still have a tiny bit of rattle every once in a while. There is also the random misfire.
  16. #1341
    I'd say either the block or deck has been shaved, you have the plug wires out of order or you're looking at the wrong pointer. There isn't much else that can go wrong.
  17. #1342
    Jun 2015
    The plug wires are in the correct order
    the block, head, and deck? has never been removed
    the pointer is the only one there. Should I show pictures ?
  18. #1343
    Jul 2019
    I have an 88 accord lxi and want to swap but I don’t want to have to modify just for fit. Can I get a suggestion on what I should get?
  19. #1344
    Feb 2016
    Florida
    Quote Originally Posted by Lamont Seawright View Post
    I believe any kind of swap there's going to be modification but probably b18. Would probably be the easiest
  20. #1345
    89T's Avatar
    Apr 2004
    The a20 intake fits the a18 correct?
    Sent from my SM-G935P using Tapatalk
    un-motivated!
    3GR
  21. #1346
    Jun 2010
    Negative
  22. #1347
    Idaho
    Does anyone have any pictures with the Carb off and any misc pictures of the carb/gaskets/parts/shit? Alot of the threads are too old and the pictures are gone. First time working with a Carb on a 3G.
  23. #1348
    What are you needing? The carb base gasket o ring I replaced with gasket paper. I did a full vac delete on my carb, its easy for me to get pictures, but I cant tell you what you should replace because I did the bare minimal. O rings on the needle and seat screw, tighten the venturis, just dont touch the accel pump unless its leaking
  24. #1349
    Idaho
    I'm new to Carbs, so everything pretty much.
  25. #1350
    Are you doing a vacuum delete or something? I can pull my carb off and take pics, thought I would for the vac delete thread anyway, but Im not sure how I can help. As far as it goes inside of it it just needs cleaned out, pull the top off and thats about all you need to do.
  2. quick question...
  3. quick question
  4. Quick Question
  5. Just a quick question....
