Page 58 of 61 FirstFirst ... 8485455565758596061 LastLast
Results 1,426 to 1,450 of 1516
  1. #1426
    Aug 2021
    1986 Accord LX
    I have a 86 Accord LX. Carbureted. What plugs give reliable and good mileage? Copper or platinum?
    TIA
  2. #1427
    NGK copper... Platium is the biggest waste of money for a spark plug, if you want long life get an iridium
  3. #1428
    Aug 2021
    Honda accord 89
    Hello guys, Do I have to order Prelude upper control arm if I put yellowspeed coilovers. Or I'm good with my stock parts with my accord 89'.
    If not do you know who sells prelude 2nd Gen upper control arm? Thanks!
  4. #1429
    No... you don't, unless you wan't fine camber control.
    You can occasionally find them on ebay
  5. #1430
    Dec 2019
    Valve adjustment order
    Trying to figure out the order in which to adjust my valves i saw a video sayin cylinder 1,3,4,2 is this correct?
  6. #1431
    https://www.3geez.com/forum/showthre...AL-(-UPDATED-)
    I would follow the book procedure until you understand what your looking at and the function of the cam and rocker arm.
    In general you adjust valves with the rocker arms on the base circle of the a cam AKA the loose side.
  7. #1432
    Nov 2021
    1983 Honda accord
    Possible alternator swap?
    I have a 1983 accord that keeps going through voltage regulators. Wondering if a later model or any internally regulated alternators would direct fit.
  8. #1433
    DX User Jacques's Avatar
    Jul 2015
    Bend, OR
    A20A3 is the woodruff key for the crank pulley and the timing belt gear one piece, or are there two keys, one for each?
    1989 Accord Lxi Coupe KA MT5
  9. #1434
    Pretty sure there is just 1
  10. #1435
    Jul 2015
    Bend, OR
    Thanks. I just got the key from Honda. By the size of it there must be two. The pulley bolt came loose, and it fell off! Engine still runs fine, so must be another one for the timing belt sproket.
    Thing is super small, and could never reach both A20A3 Lxi
  11. #1436
    Are you sure you didn't get the one for the cam?
    Make sure you put that bolt back on with loctite or all the ugga duggas your impact can handle
  12. #1437
    DX User Forte Kosakku's Avatar
    Oct 2021
    1987 Honda Accord LXI 3 door Hatchback PGMFI A20A4
    San Antonio
    anything at all on how to replace the clutch cable on a 87 honda accord lxi pgmfi ? Access under the dash looks impossible. No videos on any car with a clutch cable. I already have the parts. No threads I could find here about it. Nothing in my manuals showing me the procedure. No searching results in the forums here for clutch cable or cable show anything , not that im about to cycle through 480 pages of threads.
    Truth is as useless to a fool as legs are to the lame, and a fool repeats his folly like a dog returns to its vomit A fool also convinces himself that he is right in his own eyes and, therefore, can disregard and even ridicule other people’s advice
  13. #1438
    Pretty sure its just hooked over the end. Its tight, yeah, but you should just barely be able to see it.
  14. #1439
    Oct 2021
    San Antonio
    I found a video of a guy showing a pedal assembly outside the car and he showed me how to hook it. I managed to replace my clutch cable in about an hour. Fully adjusted. Thanks for the reply! I used a piece of guide wire to thread through the hole in the pedal assembly and firewall to help guide the new cable hook through and then it was a huge pain, but I got the hook over the top of the highest point on the clutch pedal. It was overall easier than I thought. I was afraid I needed more access under the dash to get to the top of the clutch pedal. Luckily, my hands are as small as the Japanese.
  15. #1440
    Its not a fun job, it is surprisingly cramped behind the dash. Leave that to all 3 pedals being strangely overcomplicated
  16. #1441
    Download the shop manual in my signature. It will help explain those things you can't see so you won't have to rely on YT.
  17. #1442
    DX User Jamnar_V's Avatar
    May 2021
    1989 Honda Accord LXi
    Flint Hill
    Quote Originally Posted by Jacques View Post
    The timing sprocket on the crank has a key cast as part of the sprocket.
    The key you got from Honda is, as you said, for the crank pulley only.
    are we having fun yet?
    Jamnar in Virginia
    1997 Plymouth Grand Voyager 3.3, 320k
    waiting for resurrection:
    1989 Honda Accord LXi 2.0, automatic 199k
    2000 Saturn SW2 1.9 DOHC, TAAT MP7, 278k
    1991 Geo Metro
    1985 Ford F250
  18. #1443
    Jul 2015
    Bend, OR
    Quote Originally Posted by Jamnar_V View Post
    Thanks. I fixed it. I can't believe it came loose! Should have left hand thread so when one uses for valve adj. it could not come loose!
  19. #1444
    Jan 2022
    89 Honda Accord LX
    Where can I find a replacement or upgrade exhaust for my 89 Honda Accord LX
  20. #1445
    Buy a muffler and weld it on
  21. #1446
    Quote Originally Posted by Dasiy17 View Post
    Rockauto.com has stock replacement options but if you want anything more you are own your own for custom work.
  22. #1447
    DX User 1989_3rdGenAccord's Avatar
    Jun 2015
    1989 Honda Accord LX-I 1988 Honda Accord LX-I
    Hey there, I'm back again with another question. I did a vacuum smoke test and looks like I have a leak coming from the ?"by-pass body assembly"? Here is a picture, it's not leaking from the gaskets it's at the spring. My question is where can I get another one? or can I somehow repair it?
  23. #1448
    Where was it leaking from? You probably just need to replace the gaskets
  24. #1449
    Jun 2015
    I did a vacuum smoke test and looks like I have a leak coming from the "by-pass body assembly"? Here is a picture, it's NOT leaking from the gaskets, it's leaking at the spring where the shaft goes through..
  25. #1450
    Cant see the picture yet (sometimes its delayed in showing after the post) but i would assume you can take it apart, the spring off and most likely find an o-ring in there you could replace. I dont know if its an oring but i would assume it is. By the way not all orings are equal, you want one made from the material that can withstand oil and gas. I forgot what kind that is, automotive grade at the hardware store.
    Hows that for a generic answer.
  2. quick question...
  3. quick question
  4. Quick Question
  5. Just a quick question....
