Page 51 of 61 FirstFirst ... 41474849505152535455 ... LastLast
Results 1,251 to 1,275 of 1516
  1. #1251
    Dec 2014
    Well thanks for nothing I guess
  2. #1252
    LX User AWH's Avatar
    Feb 2017
    Honda Prelude BA2 1987 2.0i-16V. B20A1
    the Netherlands
    i guess E-Bay should help you out.
  3. #1253
    Thank Honda for consistently stiffing the classic community.
  4. #1254
    Quote Originally Posted by aSoftVtec View Post
    I'd like to do both, the hub is not bad but I might as well replace it while it's off
    Pretty common on these type cars to do just the bearing.
    I know most of the new vehicles like pickups its comes together but they dont last long anyway.
  5. #1255
    Sep 2012
  6. #1256
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Quote Originally Posted by Stealth View Post
    Hey guys. I've changed out all of my exterior bulbs with LEDs, but I'm having a problem with the bulb out/brake light warning on the bottom right of the cluster lighting up. I know this is due to the lower power draw of the LEDs as compared to the original bulbs. I read on various 4th gen accord sites and on this thread: https://www.3geez.com/forum/3geez-ac...-question.html that I need to ground the white/green wire on the driver's side tail light. I cut that wire and grounded both ends of the wire. I can now replace the passenger tail light, the passenger side tail light on the trunk, and the high-mount brake light with LEDs and the indicator won't light up. However, the driver side light (both on the trunk and body) will still trigger the indicator if I replace them with LEDs.
    I thought that the driver side sensor was responsible for the driver side lights and that the passenger side sensor was responsible for the passenger side lights and high-mount tail light. Are my sensors switched? Do I need to ground a wire on the passenger side sensor?
    I've had this problem and the problem relies in that higher brake light
  7. #1257
    Sep 2012
  8. #1258
    Feb 2016
    Florida
    Why is the problem with the high-mount brake light? I can take out the bulb and the indicator won't come on. It's anytime that I remove the driver's side bulbs that my indicator bulb triggers. The wire that I grounded will let me remove all passenger lights and the high-mount bulb with no errors on the dash.
    Possibly bad wiring then did you install the bulbs without touching them with your bare hands
  9. #1259
    Sep 2012
  10. #1260
    Feb 2016
    Florida
    Yea I wore gloves when I put the bulbs in. They work great. Basically every bulb would trigger the dash light so I grounded that one white/green wire. Now everything doesn't trigger the the dash light except for the driver's side LEDs. There was no dash light before with the old bulbs so I know the wiring is fine. Something is still sending a signal to trigger the dash light which is why I'm thinking I need to ground something else. Unless maybe I wasn't supposed to ground both sides of the white/green wire?
    Here's a picture of a tail light harness. Try replacing theses. My old ones the connectors were so corroded it kept popping the bulbs or sending the brake light to this cluster
  11. #1261
    Sep 2012
  12. #1262
    Jun 2017
    1988 Honda Accord LXi Coupe
    Vancouver, WA
    Hi friends! I have a quick question about my 88 LXi 5-speed. It's fuel injected and needs a new tranny (E2Q5). My only question is, would a tranny from an 88 carbureted car be cross compatible? I've been having trouble finding info on this online. I know that the gearing is different, but that doesn't really bother me if it means it'll bolt in without issue.
    Thanks guys!
  13. #1263
    Feb 2016
    Florida
    Quote Originally Posted by asundine View Post
    Thanks guys!
    I've heard all 86-89 honda accord transmissions will swap carb gears are longer
  14. #1264
    LX User rushell's Avatar
    Oct 2012
    i have a 1989 sei and i have a carb transmission in mine the taller gears r better for the highway
  15. #1265
    Oct 2012
    i took the fuel inj trans out because i wanted taller gears
  16. #1266
    DX User rebelbabyy's Avatar
    Mar 2016
    1987 honda accord lxi
    North Carolina
    Okay I've googled and looked through the threads. Check engine light Is on code 12 egr and idle would flucuate, hesitate to go and it would bog down even with unplugging the egr. I cleaned the egr valve and the light is still on I know my catalytic converter is clogged pretty bad too but disadvantages and advantages of egr delete? Will it fix my idle and bogging down issue?
  17. #1267
    Sep 2017
    Hi, I have an 88 Accord lxi, it ran poorly when I got it, had a blown head gasket between cylinder 3 and 4. I replaced the gasket and put it back together, now it cranks but won't fire.... I'm not sure what to troubleshoot.... Any ideas?
  18. #1268
    Feb 2016
    Florida
    Quote Originally Posted by there4lcr8n View Post
    Make sure your cam and crank timing are lined up if they are pull the distributor cap off and see that the pendulum is sitting at the number one firing order if not flip your distributor key 180
  19. #1269
    Sep 2017
    Looking for headlight retractor relays on my '89 Accord LX, looked where I've been told to look for them but haven't found them at all. Any help would be appreciated.
    PS. The right headlight goes up when I use the actual headlight switch in the left, but does not retract when turned back off. Also the dashboard switch that makes them pop up without turning on the lights doesn't make either pop up or go down. Just adding this info in case it might help diagnose why they're not working properly in case it isn't the retractor relays when/if I can find those in the first place.
  20. #1270
    Those are going to be a junkyard item.
  21. #1271
    Oct 2017
    I just bought a 87 accord and the passenger window is missing and my pull a part dosnt have any 80s accord is there any other years that would fit also what are some modifications you can do with the A20
  22. #1272
    Feb 2018
    hi, i lost my old log in. i originally had a 88 honda accord lx, among 2 other early models. is there a site similar to this catering to the 2004 accord? i'm trying to find a free workshop manual. my car had the driver side busted yp from a drunk driver. 😔
  23. #1273
    Feb 2016
    Florida
    Quote Originally Posted by Bradleycole View Post
    86-89 accord? You can do all kinds of modifications to the A20 depends on how much money you want to spend
  24. #1274
    LX User Honda#1's Avatar
    1983 Accord LX hatch carb'd; 1986 Accord LX-i hatch
    Midwest
    Quote Originally Posted by oliveoil View Post
    You may want to try driveaccord.net
    I think it deals with CB and newer Accords
  25. #1275
    Feb 2018
    What's good I have a 1987 Honda Accord LX-I. None carb. Manual transmission. I'm really interested in finding out what motor swaps can fit directly in it. I am also thinking about doing a all wheel drive conversion? Any thoughts feel free to put them down
  2. quick question...
  3. quick question
  4. Quick Question
  5. Just a quick question....
