Page 55 of 61 FirstFirst ... 545515253545556575859 ... LastLast
Results 1,351 to 1,375 of 1516
  1. #1351
    Idaho
    I'd like to do the delete.
  2. #1352
    Jul 2009
    Somerville, Alabama
    wait.. what state do you live in that still requires smog on a 30+ year old car?
    In Alabama, there's emissions laws but they're not really enforced. Besides, if they were, anything over 25 years old or older is automatically exempt from Emissions testing anyways. Win Win for ME
    Shaggy
    FF II/ETC I
  3. #1353
    Aug 2019
    New to the forum could use some advice
    New to this forum, new to carburetors also. I have an 86’ Honda Accord looking to swap to a Weber carb. Anything I should do before swapping??
  4. #1354
    Aug 2019
    Quick question! Would 1985 civic corner lights fit a 1985 accord?
  5. #1355
    Idaho
    Re: New to the forum could use some advice
    Delete all the hoses.
  6. #1356
    Aug 2019
    1989 Honda Accord LS
    Whats the best spot to place a floor jack under the car to lift the rear and set on jack stands?
  7. #1357
    On the floor.
    If you look underneath, there should be a fairly big bump on the underside of the trunk floor. That's your lift point.
  8. #1358
    Nov 2019
    I just bought a 86 prelude si, I can't find parts in my area and my cat is pretty bad. Should I just delete my cat or will it run better with one. (No emmisions where I live)
  9. #1359
    Give a call to a couple exhaust shops around town and see what their prices would be to cut out the cat and weld a universal one in there.
    The car doesn't need the cat to run but it is nice to have one because it does clean up the exhaust smell quite a bit. Without a cat your car will smell like a 60's or 70's gas guzzler.
  10. #1360
    Nov 2019
    So I punched my cat out, made the car run alot better, I don't notice the gas smell cause all my cars are old 70s gassers. Thank you for the help .
  11. #1361
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    I did the same thing to my cat didn't feel a difference in anything but the smell of exhaust fumes in the car
  12. #1362
    Nov 2019
    Where would I find the ECU on my 2nd gen 86 prelude 2.0l
  13. #1363
    SEi User 86ccord's Avatar
    Middle Georgia USA
    Quote Originally Posted by Therustywrench View Post
    In the back seat, drivers side, there is an ashtray on the side panel. Remove ashtray, should be under there IIRC
    one day I'll return.
  14. #1364
    Nov 2019
    Ok I found it and it's blinks 5 times pauses and blinks 5 times again. Thats the only codes it's throwing. What would that mean? I'm really new to the older computers
  15. #1365
    89T's Avatar
    Apr 2004
    05 LED FLASH(s) 85-98 * Accord
    MAP Sensor (Manifold Absolute Pressure)
    Mechanical Problem / Disconnected Piping
    Sent from my SM-G935P using Tapatalk
    un-motivated!
    3GR
  16. #1366
    89T's Avatar
    Apr 2004
    Search trouble codes
    un-motivated!
    3GR
  17. #1367
    DX User 1989_3rdGenAccord's Avatar
    Jun 2015
    1989 Honda Accord LX-I 1988 Honda Accord LX-I
    I sold my accord in the for sale section, how do I remove it?
  18. #1368
    Quote Originally Posted by 1989_3rdGenAccord View Post
    Just update the thread to that effect.
  19. #1369
    DX User AEFCustoms's Avatar
    May 2017
    Ca5 Hatchback 87 S
    Canada, Québec
    So to start, I own a 87' Accord Hatchback Sport, i'm located in Canada, and theres no accord that has benn produced here with gaz injection.
    So, I have a couple of questions!
    I've bought an EF9 SIR and changed the bottom end for a B20B with still the head of the SIR, with a RS transmission for the highway.
    I have some Integra DA shift rods and 11inch spindles , Innovative eurethane motor mounts for Bseries, a walbro 255lph fuel pump, a p28 ecu with a chip and a front lower torsion bar to fit bseries in a 87' accord hatch.
    Presently the motor and trans are in, but the shifter rods are not fitting because the floor is in the way.
    So first question:
    Is it better to bust the shit outta my floor to be able to fit the shifter rods or modify the shifter rods?
    Second question:
    I've made a custom cover to fit the 255lph walbro fuel pump and everithing is good on that point. Now to convert it from carbu to injection I have to pss a new gaz line. What are the other things to do except that?
    Question three:
    I have an OBD1 main harness from a 92/95 civic SI, and the engine harness from a 95 Integra GSR for the P28.
    Do you think its a good Idea to take the main harness from the 92/95 civic SI and weld some wires to the main harness of my 87´ accord hatch; (exemple of the wires, check engine,rpm, oil pressure.) and then put the power on both harness.
  20. #1370
    Jun 2020
    1989 Honda Accord LXi
    Nebraska
    I have a few questions. I have a 89 accord lxi automatic 260xxx on it and I need to know what years are compatible to interswap parts out of? My driverside lower balljoint is pulling through the steering knuckle housing and I'm looking for new steering knuckle but am having a seriously hard time trying to locate one there are a few on google that look very similar but I have extremely weary of them I just need some solid 100% accurate advice from some people that know there shit about these cars so if anyone can help me that would be really swell and great of you. And one other question will a f20b fit in an 89 accord.lxi
  21. #1371
    Sep 2020
    Hey guys, I'm looking at a 88 accord and would like to pick it up but the passenger door does not open. The lock seems to actuate but it's hard to tell. Any ideas on this?
  22. #1372
    Unless it's been in an accident, it will be a relatively easy fix. I wouldn't let it keep me from buying the car.
  23. #1373
    Jun 2015
    Hey I'm back with another question although I am not new I still have trouble navigating the search. I have my manual transmission out with no reverse and whiny 5 looking to rebuild it. Where can I get the best rebuild kit for it?
  24. #1374
    The fact that you can't engage reverse, which is nothing but a gear, something is clearly wrong with the shifter. Those gears are actuated by the same shaft, nothing else is. Take the black cover off the one side and you can see 5th, stick something in the shifter and turn, it I think clockwise if you were looking at it as if it were in the car, and in and out. I think out should engage 5th, so you will see it and make sure it has a positive connection between the syncro and the gear. If you push the shifter in it should engage reverse. If you can engage it by hand but not in the car your shifter linkages are probably bent in some way. It doesn't sound like you need a rebuild, if you do you might have to take it somewhere that can source parts individually because I know of no way of bringing these trans back from the dead.
    Btw if you need the page in the manual its 340
  25. #1375
    Jun 2015
    The parts I need are..
    Main shaft. Tooth count 11th-12th-19th reverse idler 27th. 5th gear 36th. Counter gear25th. kit bearings, syncros, gaskets and seals.
    What would you suggest? The car has 100,000 miles on the transmission and I cant find anyone with a transmission that has low miles.
ID:	10371   Click image for larger version.
  2. quick question...
  3. quick question
  4. Quick Question
  5. Just a quick question....
