Okay, so I de-loomed ALL the wiring that I have, removed the 82's stock external voltage regulator, wired in the 4 pin EFI alternator plug, with the wire for the ECU, taped everything up, and plugged everything in, after removing approximately 892480298349028347 unused wires from the cabin harness.
Well....
....except for the coil, that is. There aren't any wires ANYWHERE for triggering the coil. I didn't cut any wires out of the engine harness at all, and the ones that I took out of the cabin harness were either already cut at both ends by Aaron, or were Y-connected to other systems and went nowhere (only 1 wire did this) Any wires off the ECU that were cut, go to other systems like the warning light, power feeds etc.
So, does anyone have a diagram for the B20A ignition? I'm seriously confused by having all the wires from the sensors, but none to the coil. Without a diagram, I don't even have a clue where to start. If I can, I'd like to reuse the stock 82's igniter and wiring, or at the very least the coil, which is pretty much new.
I found and printed off Aaron's B20 pinout, which is probably going to be helpful, and I also found a drawing by thegreatdane, but can't load it due to stupid 28.8K dial up timing out.
