Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: Pj5 pgm-ig wtf
    Ichiban's Avatar
    North of You.
    Re: Pj5 pgm-ig wtf
    I'm going to borrow a fuel pressure gauge and rule out things like return line restrictions and leaky injectors.
    ICHIBAN!
    "Now, even more better!"
    Re: Pj5 pgm-ig wtf
    good idea. My CRX does a simular thing but at WOT it hauls arse. To test my fucking return line i just drained it straight into a fuel container to rule it out
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: Pj5 pgm-ig wtf
    If the ECU works the same way as in the A20, when the engine is cold the ECU uses preset data for fuel. Sensor inputs (MAP, TPS, O2) for calculating fuel are used only when engine is warm -closed loop.
    Re: Pj5 pgm-ig wtf
    Sounds like its time for a OBD1 conversion and tune!
    Ichiban's Avatar
    North of You.
    Re: Pj5 pgm-ig wtf
    It has to work with the original ECU. The only things that changed are the fuel lines/pump, coil, igniter and exhaust. Everything else is the same.
    ICHIBAN!
    Re: Pj5 pgm-ig wtf
    Have you tried simply advancing the distributor while it's warm? I don't know if the B20A5 distributor would have the same map or not, but I think the computer will advance timing while cold. Perhaps after it warms up, it tries to retard it, and it goes too far back and starts running like a turd. Otherwise I'm totally fucking stumped. Maybe the ECU is just fucked.
    My friend's Civic had intermittent hesitations, and he threw every single sensor at it and every part we could think of, just like you're doing. It turned out to be the ECU.
    Ichiban's Avatar
    North of You.
    Re: Pj5 pgm-ig wtf
    Wiring in a 3gee coil today. Guess we'll see what happens.
    ICHIBAN!
