Results 1 to 9 of 9
Thread: Warm Start Issue
    DX User shadowvox6's Avatar
    May 2010
    Warm Start Issue
    Group,
    On my 89 Accord LX-i, I am having an issue where the car won't start on a warm start. I am thinking heat soak might be an issue. The starter is relatively new (less than 2 mos. old)
    Is there anything you can think of?
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    Re: Warm Start Issue
    Main relay
    Dec 2003
    Millington, TN
    If the interior of the car gets to hot the solder joints on the Main relay expand and lose their contact. Open all doors and windows let the interior cold down and then the solder contacts contract and you will be able to start the engine.
    Replace the main relay.
    Phil
    May 2010
    I am going to ask a dumb question here, but where is the Main Relay?
    There is a search feature in the header row of every page on this site. There is also a Google search feature on the homepage. I'd suggest you use it well in the future. The main relay is probably the most well known warm start issue with these cars and you asking questions that have been answered a million times already puts you in grave danger of being flamed.
    K?
    https://www.3geez.com/forum/search.php?searchid=1021046
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Quote Originally Posted by shadowvox6 View Post
    It is to the left of the steering wheel behind the coin holder, hard to see spot. Here is the autozone part#, and it is the factory Mitsuba Main Relay in a Duralast box (that is the only reason I say Autozone)http://www.autozone.com/autozone/par.../N-ii131Z9cjg2
    Also if it is a warm engine start issue (meaning not hot outside but engine warm) that is generally a ECT (Engine Coolant Temperature Sensor.
    Hot inside car= Main Relay
    Warm engine but not hot inside car= ECT sensor
    That is just basic info. And Honda dealer calls Engine Coolant Temperature sensor TW (Thermal Water) sensor. At parts store you ask for Engine Coolant Temperature sensor. Hope this helps.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    AZ
    warm start could also be the tw sensor.
    dead white and blue
    May 2010
    K?
    Yes, and thank you. I know that typically the search engine on a forum sucks. That is why I asked.
    sounds like main relay for sure. searching would of told ya that tho
  1. warm start issue
    By rocketman in forum 3geez Accords
    Last Post: 07-05-2012, 03:43 AM
  2. New twist on old issue - warm-up idle
    By omianan in forum EFI Tech
    Last Post: 05-22-2012, 10:04 PM
  3. 1988 Accord DX stalls during warm up, then no start
    By john doh in forum Carburetor Tech
    Last Post: 04-05-2011, 07:39 AM
  4. Car dies on start up after it gets warm
    By LewZur in forum EFI Tech
    Last Post: 01-18-2010, 12:15 PM
  5. Hard to start when warm
    By biggene in forum EFI Tech
    Last Post: 07-28-2006, 09:26 PM
VigLink badge
