Results 1 to 7 of 7
Thread: Radius rod polyurethane bushings
    Millington, TN
    Just a little update concerning the proper installation, Angus brought to my attention that the guide sleeve needed to be shortened by approximately 1/4".
    This is confirmed.
    I was having some vibration in the front end at about 70mph and after the modification of the guide sleeve the vibration is gone.
    Thanks Angus, now I need to do the other accord.
    Phil
    LXi User jigga89SEi's Avatar
    Feb 2003
    1999 Subaru Impreza 2.5RS, 2008 Subaru Impreza 2.5i, 1989 Sei(Project Honda SVX)
    Hampton Roads, Va
    Re: Radius rod polyurethane bushings
    What bushings are you using? Part #?
    Millington, TN
    Prothane 8-1201
    Phil
    I read that before but I don't really understand. Are you riding on the metal sleeve or on the bushing?
    My understanding is that you tighten it down until the metal sleeve is compressed tight on the rod and that the bushing is there for the misalignment as the suspension moves up a down.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    No problem Phil.
    The poly bushings are thinner. Without cuting the sleeve you're only tightning the sleeve and washers. There will be a gap between the poly bushings and the surface they mount to in the crossmember.
    CARDONE SUCKS.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    So to ensure proper installation, should you remove the sleeve, stick the bushings in and whatever is excess should be cut off?
    '89 SE-i Coupe
    Awaiting Garage
    Millington, TN
    Yep, The 1/4" should be just shorter than the 2 bushings together, so that the bushings would compress snug/tightly against the cross member.
    Phil
  1. polyurethane sway bar bushings
    By PENN in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-06-2012, 02:53 PM
  2. Radius Arm Bushings
    By 2drSE-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-26-2007, 11:13 AM
  3. do they make polyurethane rear sway bar link bushings?
    By frantik in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-20-2007, 07:08 PM
  4. Polyurethane bushings for sway bar
    By jeremiah0678 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-12-2005, 09:31 PM
  5. Free parts w/assistance in development of polyurethane bushings
    By Prothane in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-05-2003, 07:38 AM
