CzEcHy
Located on the back of the carb (drivers side), there is a dashpot looking thing with an arm going towards the front of the carb, well there is an adjusting screw located on that dashpot itself (closest to firewall)
Turn car on, turn A/C on, and turn screw slightly until the idle raises (or lowers), if it lowers go the other way. That screw is actually the A/C idle boost screw so it will only control the A/C, not the cars idle when the A/C is off.
If that doesn't work, you may need a new vacuum solenoid (which is located next to the fuel line and fuel filter (in the engine bay). J/Y would have one for like free to 5$
Good luck (and you may need to remove the air filter box to get to it, or if you have small hands you'll save yourself 5 minutes.)
