This is my first post, though I have been reading for several days now. I have an 86 LX fed emmisions carbed accord that was running roiugh when I got it. First fix was a valve adjust. That brought compression up to spec and things started looking up. Someone else has been fiddlin with it that shoulda left it be I also replaced the vacuum advance and the choke unloader. It now idles correctly and has good high end (above 3k) torque.
My problem now is that it has wimpy low end (have to slip the clutch to go in first) and it starts jerking when going down the road between 2 and 3K and you are just trying to maintain speed. Let up or mash down on the gas and it smoothes out and seems fine. Vacuum guage installed on it for testing show nice vacuum around 19" at idle and steady. WOT^ drops it right down and then it rises back up as the rpms increase. On the street it seems a bit lower than it should be but nothing remarkable.
TIA
Glenn Neff
Medford, OR
