Results 1 to 12 of 12
Thread: Header
    Dec 2009
    89 lx-I sedan :)... auto :(
    Header
    Toneloc's Pacesetter header he was selling in the "pre 1990 related" section is now mine =] just paid not cleared or shipped yet any suggestions? No welder so hopefully no fab work is needed lmao
    Dec 2003
    Millington, TN
    Re: Header
    If he has already modified it then you won't to do anything. Just plug and play. If not then it will have to have a flex joint welded in place of the ball end joint. Otherwise it will squeak everytime you move.
    Phil
    Dec 2009
    Re: Header
    actually im just using the actual header i have a fully welded exhaust from the downpipe back. im gunna install it with the header that would work right? it has a flex joint on it not ball type
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: Header
    will the down pipe bolt to the header?
    Feb 2004
    89 accord lxi
    down by the bay
    Re: Header
    If it hasn't already been done, you'll want to grind down the egr pipe where it sticks out inside the primary.
    Dec 2003
    Millington, TN
    Re: Header
    The header will most likely not mate up to the down pipe without some modification.
    Phil
    Dec 2009
    Re: Header
    if it doesnt than i cut that down pipe on bothe than either have them welded or get a joint and clamp them together either way im gettin a header on there
    Vanilla Sky's Avatar
    1999 Penalty Box
    Re: Header
    You want to use that header whole. IIRC, the secondaries on the Pacesetter are quite a bit longer than the secondaries on the stock down pipe. Just have it cut before the cat and have it all welded together. I'd go this route because you already have the rest of it welded up. You're going to want some sort of flex pipe in there somewhere, though.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: Header
    Quote Originally Posted by vanilla sky View Post
    you want to use that header whole. Iirc, the secondaries on the pacesetter are quite a bit longer than the secondaries on the stock down pipe. Just have it cut before the cat and have it all welded together. I'd go this route because you already have the rest of it welded up. You're going to want some sort of flex pipe in there somewhere, though.
    +2
    Dec 2009
    Re: Header
    Ok so i got my header in last night and i dont know what goes in all four holes. theres the o2 sensors i see them the anotherpipe/EGR? that goes into the cyl 3 pipe but theres a huge hole idk what goes in there... its the biggest one.. heres a pic
    and while i was bored i hooked up this voltage gauge i have looks neat
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Header
    Quote Originally Posted by stevo89 View Post
    That is, I beleive the air suction fitting for carbed models.. I just welded it shut. Might be too much trouble to find a bung for it.
    Re: Header
    Quote Originally Posted by 88Accord-DX View Post
    i found out that a manual tranny fill bolt fits same with the egr the automatic fill plug works too
  1. new s&s header
    By lostforawhile in forum Restoration & Custom Fabrication
    Last Post: 05-24-2014, 11:28 AM
  2. Wtb header
    By da9 in forum Wanted
    Last Post: 01-20-2010, 12:39 PM
  3. DC Header
    By 'A20A3' in forum Performance
    Last Post: 11-01-2004, 06:48 PM
  4. New header?
    By Robs89LXi in forum Trading Post
    Last Post: 02-17-2004, 09:11 PM
  5. Need a Header
    By K-MOD in forum Trading Post
    Last Post: 02-17-2004, 09:07 AM
