In that case, see if you can catch the top on the cylinder bore with your fingernail, if you can, than you have a ring ridge that needs removed. They make ridge ring remover tools. After that, you'll need to see how far the cylinder is at different points along the wall at top bottom & middle to compare out-of-round, taper, & diameter to see if it is specs to hone or it needs bored out. If the ridge isn't to bad, you might be able to hone it out with the right cylinder honing stones.
Your going to spend some time 'going under the car back & forth' a lot rebuilding the engine in the vechicle.
