Looking good! Looking forward to it mounted up in the engine bay.
me to ...
this weekend![]()
Finaly , the engine is in the car !
I made this tool to help me load the engine
brought the engine to the car on the scooter...
my friend helped me .. damn this engine is heavy..
stay tuned..
btw ,
today is Israels 63 indipendence day !!
What's the status- any updates?
did the timing but lost the crankshafts woodruf key.. waiting for a new one .
today:
installed the alternator and it's belt.
installed the torque converter and plate.
finished the right side today , belts , alternator , air condition , steering pump , water pump .
t used to have a sunroof.. probably..
next step is to install the tran. after I'll replace the oil retainers of it.
hatch is starting to look like a car again. cant wait till its running
replaced the old cheap steering wheel
with a new cheap steering wheel with a deep design that I like
the trans nightmare is finaly behind me...
installed new oil retainers
wasn't easy to install it alone , installed it from under the car by pillung it up and lowering the left side of the engine
now I need to install the water hoses and fill the water system .. fill the engine and trans with oil , connect the engine wire harness... and then... back to the carburator... where it all started...![]()
Looking good! getting close now
I want to order coolant hoses and Ebay is full of 3gees hoses.
how do I know wich to choose?
closed the transmission oil lines and filled it with oil.
installed the dist. and wires.
installed the thermostat .
because I couldn't get original water hoses , I bought long hoses and made them fit .. and filled the cooling system.
now , I need to install the webber and buy a new battery.
no one likes my thread anymore...![]()
Awesome! Its looking really good! Let me know if you have any questions on the weber install, I should be able to help out there.
Looking good!
I'm to spoiled with lifts, air tools, cherry pickers, engine stands to even try to attempt working on one in a street with that amount of work. Mad props for your devotion there....
thanks
Today ... carburator..![]()
started with pluging the holes that aren't needed anymore
base gasket
adapter #1
second gasket + adapter #2 + studs
carb gasket
carb is on
filter base gasket
filter base
filter
DONE !!
now to the linkage issue:
found in my toolbox this aluminium spacer , exact fit!
need to cut this cable end
and insert it through the screw that goes through the linkage
and then...
I drilled a hole through the cable bracket
then mounted these two
and this small bastard
and the spring
works exelent!!
now to the questions
also, to wich wire do I connect the electric choke on the carb?
thanks!!
The vacuum advance port can go to the vac advance on the dizzy or you can just leave it capped, and run vacuum from another port on the intake.
The black sensor on the top of the thermostat housing can be left as is, although you don't even need to bother with capping those ports.
Same thing for the black and white sensors on the back of the intake manifold. you can just leave them as is since they don't do anything anymore.
All of the extra wiring harness bits and vacuum connectors on the drivers side can be either entirely removed, or just tucked out of the way. They also no longer go to anything useful.
edit: forgot to answer the choke question. The choke wire needs to be hooked into a 12 volt circuit that comes on when the ignition is turned on.
But the two vacoom ports from the dizzy go to the back of the intake manifold , should I add the one on the carb to the same line?
