will it work out?
will it work out?
very good for turbo application, or fuel economy.
un-motivated!
3GR
Manual or automatic? the manual (as read other places on the forum) has longer gears on the carb'd engine. I know nothing about automatic, though. sometimes, i even forget how to use them. Wish i had a 5spd.
So, is it manual, or auto?
Good question, I'm not sure. I may drive around today with it in D3 and see how it goes.
Edit: I drove to school this morning in D3, It wouldn't shift to fourth and I couldn't get it to go into over drive. I was doing sixty in third so I'm guessing D3: 1-3 No-OD D4: 1-4 OD. Someone correct me if I'm wrong.
I love my 3Gee so much!
so you have one and still talking smack? ok blissfull arogence I guess because Ive had two different set ups with modified motors and both of them haul ass.
have to make some fine tuning adjustments but yeah, still not as neck snapping as a five speed but still ok. Can smoke the tires from a dead stop without snatching anything, just floor the gas.
without details: I have timing set to best part throttle response without preignition issues/ not sure what the numbers are.
I have TV control cable set to suit me, it goes into overdrive and stays while doing 62-70+ mph as well as shifts at appropriate rpms at part throttle, shifts with a tap of the pedal at low rpms and shifts just before redline at WOT. Took some tweaking of that adjustment to get it right, and the cable does not bind or hang and moves easy with throttle opening.
The A20A1 I had in this car earlier had DC header, weber 32/36, fresh valve job, and all vacuum removed except PVC, brake booster and vac advance.
The B20A that is in it now is set up about the same, with weber 38 at the present time. Automatic slush boxes on both motors. 15 inch alloys too, these wheels weigh around 12 lbs each.
Motor mounts filled with urethane windowweld.
Glad to help anytime you ask.
