I know there are threads but they are pretty buried, what is the upgrade alternator that was being swapped into the three g, i'm looking because my alternator is up front, and has plenty of clearance, but I'm trying to figure out how the FI accord later alternators functioned in a non computer controlled setup. I can put pretty much anything in there I want, what I would really like to use is a sixth gen civic alternator, the one on my wifes car has the same pulley grooves as the AC belt groove on our car, I tested an AC belt on it while I was doing the new timing belt. anyone know the output of these and if there's a match with a higher output, such as an integra one? The main thing I'm worried about is making the voltage regulator work without computer control. I can get these at the you pull it yard here for 20 bucks, I can't find the civic pulley so i might as well get the entire alternator. I think with my small battery a higher output alternator running on less load,will be more reliable then a smaller one running full out all the time. it's not working nearly as hard, less heat etc.
