Hi guys,
I'm back on this forum after a couple of fruitless months trying to get my 77 Accord to run right.
I've swapped out the carb for a rebuilt one from importcarbs.
When the engine is cold, the car will start up fine and run with the choke on the second detente. After a couple of minutes, I can move the choke to the first detente then off the choke completely. No problems at all at this point.
But, once the car is hot, and I turn off the engine, I cannot start car again without setting the choke on the second detente. Without the choke or when it's on the first detente, the engine will start up, then die immediately. I'd have to have a foot on the gas pedal to keep it running.
Any thoughts on what could be wrong? It's not the fuel to carb feed: I've changed filters and pump.
I want to drive this car. Not have it decorate the driveway!
Thanks!
