Results 1 to 8 of 8
Thread: seafoam question
    LXi User CzEcHy's Avatar
    Jul 2008
    89 Accord LXI
    Gulf Breeze, Florida
    seafoam question
    Changing oil tommorow, was wondering PROPER way to induce seafoam before oil change..
    I heard it was the day before an oil change pour half a can (correct me if I'm wrong), into the crankcase, and drive for a day yhen change oil.
    I deliver pizza tonight so would it be acceptable to do this? I may put 100 miles on the caar just tonight, or maybe just 20...
    I can hold off the oil change if anyone has better instructions
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    Re: seafoam question
    Read the instructions in the can itself.
    However, I am not sure that you can drive THAT long (or drive at all) with seafoam in your oil.
    If I heard (or remember) right, you are supposed to add it to the crankcase and run the engine at idle for a few minutes, and then drain all the oil.
    I used seafoam to clean my intake manifold; if you use it that way make sure to be away from your neighbors the clouds are something to behold!
    By the way, is your engine so dirty to start with? Because if that is the case I'd be concerned with that crap getting loose and clogging the oil pump pickup screen and starving your engine...
    Ichiban's Avatar
    North of You.
    I wouldn't bother to buy that shit ever. Putting a solvent into the crankcase is about the worst idea ever. The only way to clean your crankcase is to 1) increase the frequency of oil changes and 2) use a high detergent oil, like a diesel grade (Shell Rotella T 10w-30 comes to mind).
    Even cleaning the intake/valves/chambers can be done with plain old ATF. Pour it into the throttle body so it reaches all cylinders evenly and slowly increase the speed until the engine just dies (you don't want to hydrolock the motor). Let it sit and soak into the carbon deposits for 15 minutes or so, then start and run the engine hard. The ATF heats up and gassifies when the engine runs, breaking up the carbon deposits from the inside. It also has a detergent effect, and is likely way cheaper than Shitfoam.
    I seriously would never use that crap.
    ICHIBAN!
    "Now, even more better!"
    Jul 2008
    89 Accord LXI
    When we adjusted my valves it had very very light sludge on two tinyyy areas, I just wanted to clean it nicely and use the rest of the seafoam for the carburator, then throw some fresh oil in and engine restore.
    Apr 2008
    Atlanta, GA
    Cool Re: seafoam question
    Quote Originally Posted by Ichiban View Post
    x2
    I use Rotella T 15w40 (I cannot get 10w30 in dino form)
    Anyway, it works fine in hot weather and it is not that bad for the winters in the south...
    bridgewater.NS Canada
    So can we run diesel oil in a gas engine?
    Yes, it just has more anti burn and aniti wear stuff in it which is great, i run 15w40 chevron dello in the 4th gen, was burning oil every 1k with 20w50 in it, now it only uses a quart every 4k.. so yeah it helps alot also made the engine quiet, was pretty loud with the 20w40 gasoline engine oil in it...
    Apr 2008
    Atlanta, GA
    short answer: yes
    long answer: Rotella, Mobil, and Chevron also meet API standards for gasoline engines (SM for Rotella T, and most likely for the others)
    http://www.shell.com/home/PlainPageS...xpert_faq.html
  1. Seafoam vid!!!!!!! ;D
    By gfrg88 in forum Classic Preludes
    Last Post: 04-05-2011, 07:36 PM
  2. seafoam question real quick
    By geeteedan in forum 3geez Accords
    Last Post: 06-14-2010, 07:11 PM
  3. Seafoam with 260k?
    By dmbshu in forum EFI Tech
    Last Post: 09-02-2007, 09:53 AM
  4. My Adventures With Seafoam
    By mkymonkey in forum 3geez Accords
    Last Post: 08-11-2007, 09:54 AM
  5. Seafoam
    By Micah 89LXi in forum Classic Honda Community Chat
    Last Post: 02-01-2006, 09:59 PM
