Whats the status, you been away way to long. LOL
After 20 years of drewling over an Aerodeck I finally bought my own.
Hello there,
Fixed 140 picture links.
Was a intensive job, but done.
Imageshack is not my friend.
All in Dropbox now.
My best friend gave me a nice birthday present a while ago. My spare steering wheel wrapped in fresh leather.
I think it's perfect.
Wil post some pictures from the fog install soon.
Thank you! Is there a reason I'm not seeing any in the thread?
Serious?
Must be a dropbox setting. I see them all.
I look into it.
Very nice car and story! And great that you had the rust repaired! I see you had it painted with the rear glass pieces installed. How is the finish of the paint near the trim around the glass?
Take care of that mint bumper support They are no longer available from Honda and you probably bought the last one. Be sure to grease it up good.
I'm curious just how much of a difference the sound deadening has made on tire noise in your Aerodeck?
The steering wheel is top notch upholstery work, and thumbs up for sticking with the stock wheel.
Pictures are showing for me. But the way it works with dropbox means that if you have slow internet they may time out and not show.
Thank's!
The trim from the rear glass was removed before paint, so the paint is under the trim and looks like it is suppose to.
Have to take of my rear bumper in spring. somebody backed up into it, without leaving a note.
The bumper is pushed in a few cm on one side...
The Dyna helps to reduce the tire noise, but mostly it takes out the resonance from the metal panels.
That helps for better sounding audio. The system was sounding very good, but my audio build is some year's ago, the speakers need to be replaced, fucked them up. Again.
Rear speakers are blown up and 1 tweeter in the front is damaged too.
I'm wondering who's seeing my picture's now, after i changed my photo links to dropbox.
I tested many devices in Holland, they all show the pictures.
Thegreatdane is seeing them. (Denmark)
But it seems that Dr. Snooz is not getting them in the thread. (USA)
Is someone from Amerika able to see my thread pic's??
I assume you glued the trim back in then as they normally are clipped in behind the glass and glued together with the glass. Very annoying methods that honda decided to mount trim on a lot of models back then. The Aerodeck rear sticker they can no longer be found at Honda but if you're interested in having it then someone is making replicas of it: Honda : Accord aerodeck center garnish reproduction decal
(I have no knowledge of the quality of the decal nor the seller). I am seeing your pictures from south america by the way.
Your right. I took out the glass from my spareodeck and saved the trims over there.
Adapted them to be glued in the red car. It helps to have spares.
Used the hood, bumper and a headlight from the spareodeck as well, after I crashed it.
I like the Aerodeck sticker. I might order one in black.
Both my previous red Aerodeck’s had this trunk sticker. But not my current one.
My previous Deck’s both had the ‘exclusive edition’ sticker on the front fender as well.
And again, not on this one.
After the crash and repaint I removed the Plastic Honda and Accord Aerodeck logos from the back.
The little holes been welded up.
Your far away from home.
Good to hear the pictures are showing.
3Geez resident body man
Owner of Wreck-less auto body
Don’t know about the license plate mount, for as far as I know the plate is never mounted on the rear bumper. Can not think of a reason why it’s made this way. Only thing I know is that this center peace is removed when a tow-bar is mounted. The license plate is directly on the tow-bar then.
I'm seeing this one now.
How are you inserting them into the thread? The HTML code looks weird. Here's your link to that pic: "https://www.dropbox.com/s/6mbt3nlsi5ajj83/IMG_2455.JPG?raw=1". That link shows an error in the HTML code. If I copy it into my address bar, it goes to here: "https://dl.dropboxusercontent.com/content_link/AAORstapCoXFDyPLVsbdKzjA524Pp2rmTqoWJqoRapkCK9qVWg ZfatnZq3sjHWai/file" and I can see it.
When I add pics to a post, I click the "Insert Image" button, then choose "From URL", then uncheck the "Retrieve remote file and reference locally" box. That always does the trick. At least until my hosting site changes their mind. Also, I don't know if there are a few options for showing pics remotely using dropbox, so maybe some different options on that end would work better.
Any new updates in 2019?
