Well i have poured over your guy's forums and found out many interesting things. One thread in particular aimed at increasing shock travel with a lowered suspension peaked my interest. I decided I would do this mod after hitting some raised castings in the street and ramming the shock shafts past the bushing. Initially I thought I have burst the lower washers but now I have realized they were not put back in because I have coilover sleeves and the washer are attached to the shield.
I was also involved in a small rear ender which made me realize that i had to do something that appeared a little more "stock" since I will almost surely be going into the insurance facility, and I am confident that if I pop my hood with long carriage bolts protruding into the engine bay theres a pretty good chance I won't be driving out. So, the thinking began.
It isnt some genius idea, merely and expansion upon the work already done by the people behind the first version.
it isnt done yet but I am very tired of hearing my shock smash around so the welding should be done this week and thats really the last step left at this point.
I guess I will also include my suspension setup aside from the top hat mod in this post aswell.
Pictures with captions.
Rear hats marked with white for cutting, removing the bushing cups from the perch section.
Fronts marked likewise
Cut up top hats
Front hat cut
Section of pipe will be placed in between
You can see that the pipe is slightly larger than the cups, this is a front. I believe the tubing I got is 1-5/8" but don't quote me on that at the moment.
Rear tubing was larger as it has larger bushings, this tubing is 2" I.D.
Rear tubing
Front tubing, Hondamonster is going to get back to me about hood clearance, then I will trim the sections to the correct lengths.
