Results 1 to 10 of 10
Thread: brake booster check valve - low idle
    Sep 2010
    1989 Accord DX 2dr
    Where exactly is the brake booster check valve located on an 89 Accord 2 door DX coupe. I am having a low idle problem when hitting the brakes. It idles at 500 or less and will completely stall sometimes while on the brakes. I have tried reading alot of the threads and thought i'd try to clean it and see if that helped.
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Re: brake booster check valve - low idle
    It is #6 to give you an idea of its location.http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    Sep 2010
    1989 Accord DX 2dr
    Thank you. When it is removed do you have to rebleed the brake system?
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Quote Originally Posted by pink_sleeve View Post
    No, bleeding is not required. The check valve is in the vacuum (air) system for the brake booster that gives you what are referred to as power brakes. There is not and should never be brake fluid in this vacuum hose containing the check valve you are removing.
    Sep 2010
    1989 Accord DX 2dr
    Quote Originally Posted by car6289 View Post
    Am i correct in saying it's around an inch in diameter and clipped to the upper firewall above the master cylinder? The hose to it comes directly out of the master cylinder correct?
    Sep 2010
    1989 Accord DX 2dr
    Ok i have it out of the car.... Should i be able to blow through it easlily or should there be resistance? What do you clean it with?
    Check valves allow flow one way only. I think there is an arrow on the plastic valve. So in one direction you should be able to blow threw it and the other it should be checked off no flow.
    car6289's Avatar
    Jun 2002
    Correct hose. It actually is connected to the brake booster (round black thing) not the master cylinder. Pull the hose off the booster with the engine running at idle. There should be vacuum available at the end of the hose. Your idle might drop because you have just created a vacuum leak by performing the check valve test. If there is no vacuum available the check valve is stuck closed. If you have vacuum available the check valve is good. Your idle speed reduction with brake pedal application could be from an internal vacuum leak within the brake booster itself.
    Sep 2010
    1989 Accord DX 2dr
    I can blow through it. But it has quite a bit of resistance...
    Sep 2010
    1989 Accord DX 2dr
    Thank you guys for the help. I ended up running some seafoam through the tank for now and it seems to run better now then when i first got it lol... It's idling right around 800ish rpm where a week ago it was idling around 1000 rpm. But yesterday it was acting up and only idling around 300 and under and even stalling : (
  1. Replies: 4
    Last Post: 08-11-2009, 08:38 PM
  2. Wet Brake Booster
    By bushbean in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-12-2009, 05:33 PM
  3. brake booster
    By 87newb in forum 3geez Accords
    Last Post: 05-22-2008, 02:24 PM
  4. Brake booster...
    By ahbeyra in forum Carburetor Tech
    Last Post: 07-19-2003, 05:05 AM
  5. brake booster
    By 86accordlxi-fi in forum 3geez Accords
    Last Post: 01-15-2003, 12:29 PM
