Results 1 to 8 of 8
Thread: Low-beam headlight problem
    DX User Haxxorz's Avatar
    Jun 2009
    1988 Honda Accord DX
    Portland, OR
    So randomly it seemed, one of my low-beams went out. So I thought it was bulb, but when i replaced both; one side still didn't work. Checked the fuses and the one blows whenever i try and put another in. What's your ideas? short somewhere...but where?!? I've been a jerk and just drove with brights everywhere in town haha.
    Apr 2008
    88 LX sedan (sold)
    mi.
    Re: Low-beam headlight problem
    check to see if your wire harness is loose behind the eyelid/mount. might be rubbing/binding enough to break a wire. ??
    ^ Also, that thing gets covered in that yellow goo. Clean it off.
    Jun 2009
    Portland, OR
    Also if can throw something out, both my high-beams work fine. I kinda feel like its not the connection then, ya know? All i know for sure is the left low beam will usually work and the right will blow a fuse everytime i try it. immediately
    car6289's Avatar
    Jun 2002
    1989 Honda Accord LX , 2009 Honda Ridgeline & 2005 Honda Civic (1987 Accord LX - RIP)
    Abbotsford, B.C., Canada
    Most likely wire(s) behind right headlight bucket are broken and shorting out. Had same problem on my old 87. On my present 89 I have never retracted the headlights, they're always open and have never had any headlight wiring issues. I don't even know if the retractor motors even function anymore.
    Nov 2002
    Ridin Dirty in New York
    Quote Originally Posted by car6289 View Post
    this
    Quote Originally Posted by Haxxorz View Post
    One plug, three holes/connections. High, low, ground. If the low goes out, and the ground and high-beam doesn't, the high-beams won't be affected. Like I said, clean them, and like someone else said, check for a solid connection.
    Jun 2009
    Portland, OR
    Alright I'll get on that. Thanks guys for the input. Let ya know if I can figure out where the problem is
  1. One low beam headlight not working.
    By Legend_master in forum 3geez Accords
    Last Post: 04-09-2012, 08:16 AM
  2. Headlight Sealed Beam H4 conversion
    By 1stgen!!! in forum 1geez Accords
    Last Post: 12-16-2011, 04:07 PM
  3. Headlight low beam probs
    By Forgar_88 in forum 3geez Accords
    Last Post: 12-23-2005, 11:48 AM
  4. Low Beam Problem
    By kaltenacht in forum Interior & Exterior Care
    Last Post: 06-25-2005, 07:53 PM
  5. Replies: 1
    Last Post: 05-23-2004, 02:47 PM
