Results 1 to 5 of 5
Thread: Power windows slow??
    King Peetis's Avatar
    Atlanta, ga
    My driver side window goes up and down like Apollo 11 but my passenger side window creeps like a thief in the night. What’s up with the windows? Do I have to live with this or is it an easy fix like replacing a regulator or something??
    Re: Power windows slow??
    Try lubing things up real good first. Oil all the pivots, grease the gears and hit the felt guides with silicone spray. If that doesn't work, replace the regulator.
    Agreed,
    Clean the track and grease them up real good, mine was like that when I first got her
    Atlanta, ga
    Agreed,
    I greased everything and granted, its much better but still takes about 10 seconds to go up and just a couple to come down. I going to assume its the regulator. Thanks fellas
    you can try this, jump the motor to direct battery power and see if it goes any faster. That will tell you if you are gettng a voltage drop thru the relays, switches, and control box or if you have a motor/regulator issue.
  1. [General Info] Fix Your Slow Windows
    By Dr_Snooz in forum How To
    Last Post: 12-15-2012, 12:52 PM
  2. slow power windows
    Last Post: 08-06-2012, 06:06 PM
  3. Power Windows SLOW!
    By smoothcriminal in forum 3geez Accords
    Last Post: 03-09-2011, 09:46 PM
  4. Slow power windows
    By 89accordex in forum Classic Honda Community Chat
    Last Post: 01-27-2004, 09:30 PM
  5. Slow Windows
    By WhiteSpecV in forum 3geez Accords
    Last Post: 10-22-2002, 06:27 PM
